Author Topic: Bonnet insulation.  (Read 3395 times)
Offline tweed
Re: Bonnet insulation.
« Reply #10 on: 13 January 2013, 23:09 »
I found it transferring heat to the bonnet do put it back in.
Did you use a heat gun? Did you take a engine bay temperature before and after? Or just place your hand on the bonnet and thoughts that's hotter than before, it must be taking heat away from the bay and transferring it to the bonnet?
I think you will find that it's holding heat in and the bay and bonnet temp will raise.
It does not transfer heat from the bay to the bonnet!  :rolleyes:
Offline tweed
« Reply #11 on: 13 January 2013, 23:11 »
Think its just sound
« Last Edit: 13 January 2013, 23:15 by tweed »
Offline Foreveryoungaus16v
« Reply #12 on: 14 January 2013, 08:38 »
 :grin: agree with tweed
163 BHP (TSR POWER RUN)
Offline tshirt2k
  • Been there...Done that...
« Reply #13 on: 14 January 2013, 10:04 »
 Remember I have a turbo at back creating more heat than usual.
After getting bonnet painted, I noticed the paint needed polishing again after a short while. The painter mentioned something about too much heat causing faster paint curing or sinkage. The only thing that I'd done is removed bonnet insulation. So replaced it.
Just like a phenolic gasket it doesn't stop heat transfer, but I think it slows transfer And for the phenolic gaskets on my inlet manifold test l, I measured temps before and after as shown in my thread. .  :wink:
Mk3 ABF 16VT Megasquirt V3
Offline tweed
« Reply #14 on: 14 January 2013, 10:26 »
That makes sense! Unlike your first reply  :grin:
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #15 on: 14 January 2013, 11:36 »
Iv never had issues with my paint on my bonnet Russ, and as u know I have a big turbo on mine
The insulation on the underside of the bonnet keeps the heat in the bay too much IMO and that's not what I want
They also hold moisture too and go damp if the car is not used for a few days (in colder months etc) leading to oxidization of parts of the engine
This is just what I found personally and that's why mines not fitted, oh and also because my engine cover is pretty close to my bonnet as it Is  :grin:
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline tshirt2k
« Reply #16 on: 14 January 2013, 11:55 »
Cold and damp! The joys of northern life eh?? :evil:
Offline F17BAD
« Reply #17 on: 14 January 2013, 13:19 »
Hahahaha  :grin:
