Author Topic: heated wing mirros  (Read 4003 times)
Offline dubb
Re: heated wing mirros
« Reply #10 on: 11 December 2014, 10:31 »
Are these standard on any type of model? I'm not sure if my 16v has them installed, are they easy fitted/plug for them already wired up?
Offline gasketface
« Reply #11 on: 11 December 2014, 18:06 »
You should have them as standard  :smiley:
Offline itavaltalainen
« Reply #12 on: 11 December 2014, 18:19 »
16v should have it as standard, all models, certainly GL and upwards had it as standard.
you could convert it so it heats up with ignition.... (needs a small circuit with an NTC and a transistor so they only come on when it's cold), then you dont have to turn on rear heating which can burn out if you leave it on with no ice or fog on back
