Author Topic: 42 draft designs pillar pod gauge has arrived few questions...  (Read 3645 times)
Offline AD1.8T
Re: 42 draft designs pillar pod
« Reply #20 on: 12 January 2013, 13:39 »
So the boost gauge finally arrived today so naturally i fitted it in the pouring rain .....
Im still learning about turbo engines so bare with me !!
On idle its at -10
With foot to the floor its at 8psi which is correct as far as ive been reading
If say doing 65/70 and i let off the throttle and just coast it drops back down to -10ish
And driving SENSIBLEY so not going above 2.5k it doesnt go above 0 ?!
Does all that seem as it should ?
Offline AD1.8T
Re: 42 draft designs pillar pod gauge has arrived few questions...
« Reply #21 on: 12 January 2013, 14:53 »
Think it blends in quite nicely  :cool:
And 1 from eye level ....
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #22 on: 12 January 2013, 17:28 »
I'm assuming the -10 reading is psi not in hg?
Offline AD1.8T
« Reply #23 on: 12 January 2013, 17:37 »
I dont know what hg is but the gauge is psi ...
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #24 on: 12 January 2013, 17:42 »
in hg - inches of mercury, usually what boost gauges read below 0 but not all
-10psi is around -20in hg which is about right but maybe just a tiny bit low. I'd have a good look round all the pipes to make sure everything is secure. Also was that reading on a warm engine?
Offline pickles
  • Next!!!
« Reply #25 on: 12 January 2013, 17:59 »
Funky :), i want 1 lol, wrd you get your gauge m8
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline AD1.8T
« Reply #26 on: 12 January 2013, 18:54 »
-9 was first start then crept up to -10 then when fully up to temp it went to -11 if theres a minor leak i would put money on it that its the IC to Pancake coupler as i struggle to get it on all them months ago !
The gauge is from egay mate put in digital boost gauge it should pop up 1s from hk the others from here which is abit more costly but i didnt want to wait 20 odd days so i paid the extra £3
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #27 on: 12 January 2013, 20:31 »
unless you make an effort to make the revs climb (ie plant your foot or go up a hill) you won't see much boost on the gauge under normal driving
-11psi is about right mate. It will be lower when you first start it due to the auto choke messing with the revs
Offline AD1.8T
« Reply #28 on: 12 January 2013, 21:14 »
Nice alls as it should be then  :grin: it is a touch on the bright side at night though and i cant really wire it in to the dimmer as the whole things being powered not just a led  :undecided:
Offline pickles
  • Next!!!
« Reply #29 on: 12 January 2013, 22:14 »
does it change colours  :grin:
Mapped
Nearly S3 time  :)
