Golf mk4
Wazzzer
Accelerator not working (intermittent)
Topic: Accelerator not working (intermittent) (Read 1962 times)
mar_k
Re: Accelerator not working (intermittent)
Reply #10 on:
07 June 2013, 22:47 »
The lambda shares the same ground/earth as the drive by wire system.
Both ground directly to the same part in the ECU, if you get a short at the lambda you will damage that part of the ECU and it will cause the throttle not to work.
Golf mk4
Wazzzer
