Author Topic: engine cover  (Read 1454 times)
Offline mossy1969
engine cover
« on: 08 January 2013, 06:01 »
hi there does anyone know how to tighten up the plastic cover in the engine bay as mine for some reason is a little slack,,,,,cheers
Offline bacillus
Re: engine cover
« Reply #1 on: 08 January 2013, 08:32 »
If the cover is a bit loose then I suggest you check to see by removing the air box and make sure all four securing grommets are present and correctly seated.
Without traction power is nothing!
