Author Topic: Matt's Accuair GTI - Now A MK5 R32!  (Read 113230 times)
Offline matttrance28
Re: Matt's Accuaired GTI
« Reply #80 on: 07 January 2013, 10:44 »
I was just fed up of scraping sumps and subframes
I had some spare cash I earnt and saved up and thought I would treat myself,
yes its an attack to the company, but when you pay out a lump sum to a proffesional you expect a decent job back in return, it comes with any business, they've just caused me more grief than it's worth
besides its my car and I can upload pictures of it freely, they can't stop me doing so
yes I agree this may of gone out of hand by the actions I've taken, and I could've approached it in a more calmer and respective way towards them
« Last Edit: 07 January 2013, 10:46 by matttrance28 »
Offline RandomJord
« Reply #81 on: 07 January 2013, 10:56 »
is
www.fab-finishing.com[/b]]www.fab-finishing.com
the company that cannot be named on E38?
Skoda Octavia VRS DSG (soon!)
Skoda Rapid Spaceback
An a Signum for towing me old caravan!
Offline RandomJord
« Reply #82 on: 07 January 2013, 10:56 »
Also, great car mate, looks spot on.
« Reply #83 on: 07 January 2013, 11:15 »
Yeah they're on edition 38, but not an active member, i think most of their sales are through either seeing the work at car shows, or their website / facebook page
They own a Bentley passat
And thank you very much :)
« Last Edit: 07 January 2013, 11:16 by matttrance28 »
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #84 on: 07 January 2013, 12:05 »
The Pissrat looks sweet though...  :lipsrsealed:
Offline Lewy
« Reply #85 on: 07 January 2013, 12:32 »
I feel your pain mate.  But I didn't get as badly bummed as you did...
« Reply #86 on: 08 January 2013, 00:39 »
It does, thats why i trusted them seeing their work in the flesh, then this, it just doesn't add up, when i first arrived it was literally a little barn they've just moved too, i was expecting some big factory or warehouse or something
They don't even do this as their full time jobs, i didn't know this until i asked to come up on a weekday and they said i cant as their  at normal day to day jobs during the week, and fab is an evening / weekend thing  :sad:
« Reply #87 on: 08 January 2013, 00:40 »
Yeah it's sad to hear someone else has too, but I hope I've put some facts out there and for people to see and not to put as much trust in them as I did.. :cry:
« Reply #88 on: 09 January 2013, 00:34 »
this was mentioned by a friend on another forum:
Believe it or not Matt hasnt portrayed just how bad this was. I've seen this build first hand and it is truly disgraceful. Whilst i'm not even close to an air ride expert its glaringly obvious that everything's been done wrong, there was no thought or planning involved and really really simple problems could have been avoided if they took 2 mins to think about it first:
- Tight bends in the pipes rather than smooth curves which have now caused leaking
- Shoddy earth's, and I mean shoddy - self tapping screw into the boot floor, with no rustproofing on either side.
- Appalling transitions into the car, pipe's bending at sharp angles through grommets in holes too big for them and "remedied" with silicone! As this has come away you're left with sharp edges rubbing on air lines.
- Air hose's cable tied to the fuel lines under the length of the car
- Braided hoses loosely tucked behind the solid brake lines at the front wheels. Massive potential for these to rub.
- Wrong wheel fitted front to back and then bodged with a spigot to get Matt out of the door - scratched wheel/coilover, ruined speed sensor and intermittent abs problem, possible bent abs ring?
- Air Tank frame was so weak it wobbled forward and backwards whilst driving
- Tank fitted upside down with no drain installed
- Compressors fixed straight to boot floor using self tapping screws and rubber washers rather than on a false floor with proper insulation and sound deadening - the sound was ridiculous!
- No sound deadening at all, unless you include the swarf/rubbish etc they didnt even bother to clean out of the boot
- Auto dim on the controller not wired in
- Height controller wire bent and crushed, not properly routed
- Power lead run through the bonnet release grommet?! why! there is a perfectly useable grommet literally next to it! resulting in completely soaked carpets and a broken scuttle panel
That's just what I can think of off the top of my head. All in all a very poor show, and I'm not even talking in terms of the money involved - Luckily Matt has common sense and looked at the install and got advice from friends and people who have experience with air ride. But Mr Average Joe who has no knowledge or experience with cars (but money to spend) might not have looked at the install - afterall he's paid a lot of money so it must be fine, right?
There was several bodges that caused problems, mostly financial, but worryingly some had the potential to be dangerous. Just think what could happen if one of the lines split whilst on the motorway?
Personally I dont think the £400 Matt got back is enough to cover the costs involved in ripping out and re-installing correctly, let alone all the time and effort involved. All in all a very very poor show from FAB.
This is all true.
« Reply #89 on: 09 January 2013, 00:36 »
Also today i contacted accuair about the issue, i'll see what they have to say, I've linked to build threads on other forums etc, hopefully this will put the message across clearly, ill update anything else if i hear back.
The guy also remove me off facebook today, after seeing all my status updates  :cry: guess he was getting annoyed, but before i was removed i saw this, either something really bad happened at the same time, or its about me, i don't think its a coincidence as i was shortly removed after lol
