Author Topic: oil leak :(  (Read 1990 times)
Offline PeteGTI1990
oil leak :(
« on: 04 January 2013, 10:30 »
I have noticed an oil leak on my mk4 1.8t agu.... Not sure where its coming from. Not loosing lots of oil but loosing enough.. Lost about a litre in just over a month.. By the smell of it its burning a bit of it too.... Any ideas on what it could be.. I know its not much to go on but looks like it is coming from round the back of the engine.
Offline Luke1981
Re: oil leak :(
« Reply #1 on: 05 January 2013, 18:15 »
The best thing to do is get the car on a ramp and have a good look around the usual culptits such as the sump, oil filter housing and oil pump. If its losing a litre a month it should be obvious where its coming from. If the engine is filthy then you might have to get it steam cleaned to pinpoint the problem.
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline PeteGTI1990
Re: oil leak :(
« Reply #2 on: 05 January 2013, 18:45 »
I have tried to see where it's coming from but the engine if filthy... Taking it down my local garage next week so they can find the problem.
Offline 52GTIPETE
Re: oil leak :(
« Reply #3 on: 22 February 2013, 16:58 »
I had this same annoying problem. After removing the plastic covering on top of the engine I found the breather pipe to the far right had a huge hole in it.
Offline kane_turbo
Re: oil leak :(
« Reply #4 on: 10 March 2013, 22:56 »
mine hasa leaky rocker cover. not good as leaks into coilpacks :( on the list to do though :D
