Author Topic: OEM R32 Exhaust.  (Read 3518 times)
Offline damien010685
Re: OEM R32 Exhaust.
« Reply #10 on: 04 January 2013, 23:47 »
There a bit far from scotland and no prices listed like i bet its not much cheaper to be fair... And a v6 plus milltek for me is utter win!!!
Offline wotavudunn
« Reply #11 on: 05 January 2013, 10:39 »
scotland??? the guy who made the thread is from Manchester and a full cat back system costs about £420 from them.
« Reply #12 on: 06 January 2013, 11:11 »
Aye and im saying im from scotland would be a fair bit to travel..... and its nae a million miles cheaper is it £420
Offline wotavudunn
« Reply #13 on: 06 January 2013, 12:58 »
congratulations your from scotland but seen that im talking to the op this doesn't apply to you.
« Reply #14 on: 06 January 2013, 15:20 »
Fair doos
« Last Edit: 06 January 2013, 15:25 by damien010685 »
Offline MattyV6
  • Mk4 .:R32 - The Black Destroyer
« Reply #15 on: 24 January 2013, 20:04 »
I have a Milltek fitted to my R32 and agree, they are a little overpriced for £500. Custom will be cheaper and your be able to almost pick your sound your after with different size boxes. Having one box or 2 rear cans etc etc.
They do sound good tho, cant knock what they do produce.
Here is my non res milltek and de cat. Turn UP your speakers for full effect. Spits flames too :)
Click the higher res option.
http://www.youtube.com/watch?v=ZB6ONP-Smfw
Not in any way standard :) Dyno Dynamics RR - 280bhp
Offline barrym381
« Reply #16 on: 24 January 2013, 20:16 »
that sounds fu*kin great  :evil:
« Reply #17 on: 24 January 2013, 20:20 »
Martty that sounds epic!!!! So does the miltek non res not already have all the silencers removed?
Offline davemk4
« Reply #18 on: 24 January 2013, 20:56 »
holly mother of christ! my ears just bled  :shocked: :shocked: :shocked:
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline MattyV6
« Reply #19 on: 25 January 2013, 10:10 »
Hahaaa cheers, its pretty loud lol.
The actual Milltek 'non res' rear box is exactly the same as the Milltek 'res' rear box. Res and Non Res are referring to the silencer about 2 foot in front of the rear box. With the res you have a silencer, the non res you dont.
In that vid i'm running a de cat and a milltek non res set up.
You can almost bolt a Milltek system straight onto your 4motion. You will need to remove the rear towing eye as this gets in the way of the right hand side pipe. You might need to do a very slight bit of pipe cutting to get it sitting the correct length.
