Author Topic: Heated Seat Woes *Fixed*  (Read 1878 times)
Offline benjy_b
« on: 28 December 2012, 01:06 »
Having fitted heated seats to my CL Estate, I'm havin dramas with their operation.
Can someone explain their operation?
Currently:
Drivers seat switch clicks loudly between 0-1 but you don't hear the relay engage until betwen 4-5.
Passengers seat switch doesn't click loudly between 0-1 but you hear the relay engage, no noise from the relay between 2-5.
Drivers seat gets nice and toasty.
Passengers seat doesn't get warm.
Finally, does anyone have a wiring diagram for the heated seats?
« Last Edit: 13 January 2013, 02:46 by benjy_b »
1995 MK3 Volkswagen Golf 1.9 TDI CL 3 Door - White
Offline benjy_b
Re: Heated Seat Woes
« Reply #1 on: 28 December 2012, 01:24 »
Hmmm, I think I've sussed the relay noises.
Passenger seat was cold, therefore thermistor switches seat on straight away.
Drivers seat was warm, therefore thermistor switches seat on between 4-5.
I think I have a broken passenger element  :sad:
Offline madmanmart
« Reply #2 on: 28 December 2012, 09:54 »
Right first thing I would do is swap the relays round to rule them out.
Then I would do swap the seats round to rule the wiring to the dash out.
Then you will know the fault lies with the element (which it know doubt will be).  :grin:
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline benjy_b
« Reply #3 on: 11 January 2013, 19:44 »
Managed to fix the fault! :cool:
Turned out to be a broken element, just on the left passenger seat bolster. I soldered it and protected the joint with heat shrink. Now working like a good 'un!
What a pain in the a** it is to get the seat cover off the foam base!
