Author Topic: Mk4 Golf gti 150t  (Read 1596 times)
Offline mk4melv
Re: Mk4 Golf gti 150t
« Reply #10 on: 28 December 2012, 11:27 »
Ive seen this car around as im from north devon its a tidy car from the outside not sure about inside or mechanically tho
Offline Rob Zombie
« Reply #11 on: 28 December 2012, 12:32 »
as per the above - its had a bit of money spent on it already which will save you some. As long as it comes with full service history and has been well kept... these thing go on and on...
Performance mods: Revo stage 2 map, 5 Peice Hose Kit & TIP, Evoloution Motorsport Air Filter, N249 by-pass, Forge spliter valve, ECS N75 Valve, KW 50mm springs &shocks, Front & Rear Eiabach ARB, Full Milltek Turbo back exhaust.
BHP: 231
TRQ: 251.7 lb-ft
Offline JimBR
« Reply #12 on: 28 December 2012, 13:15 »
The blocks are fine (generally - if well serviced, pick up replaced, not running 300ftlb+ on stock rods) its the stuff bolted to them that normally goes wrong.
Turbos, flywheels, sensors, breather system, ect..
