Author Topic: best induction kit for golf 1.8 turbo  (Read 9533 times)
Offline davemk4
Re: best induction kit for golf 1.8 turbo
« Reply #30 on: 28 December 2012, 20:24 »
i like the r tech one but i wanted a kit to buy but they wouldnt sell direct only fitted me want it now lol
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline davemk4
« Reply #31 on: 28 December 2012, 20:25 »
Do you know if they sell the sheild seperate?
not when i asked few week back shame as looks better than the plain alliminum one on ebay
« Reply #32 on: 28 December 2012, 23:37 »
Just wrap the ebay one in vinyl, will look loads better.
Offline JimBR
« Reply #33 on: 29 December 2012, 05:16 »
Ive got the aluminium ebay one, it fits okay but the finish is pretty awful. I just gave mine a key with some wet and dry and gave it a coat of matt black. It looks 100x better.
Offline davemk4
« Reply #34 on: 29 December 2012, 06:32 »
Good idea good paint before fitting
Offline ReDBull
« Reply #35 on: 29 December 2012, 11:13 »
If your feel flush there's always the 42 Draft Design filter, velocity stack and shield.
http://www.42draftdesigns.com/categories/products/in_mk1tt_hfis.html
Bill at B5 also doses a plastic velocity stack or billet with filters to match.
03 210 Seat LCR. Badger5 V2.2TIP, Fordge 007p, Wellycooler, Quaife ATB LSD, Nuespeed ARB's, KW Clubsports, 330mm discs, 3" turbo back de cat and still on the standard map!
My project thread: http://www.golfgtiforum.co.uk/index.php?topic=241116.0
Offline davemk4
« Reply #36 on: 29 December 2012, 11:35 »
That filter set up looks fantastic
Offline Nino
« Reply #37 on: 29 December 2012, 13:03 »
I have got a really good setup just need to make my own heat shield and fit my other bits and bobs, basically i got a HUGE cone filter from ram air (will require a custom made heat shoeld by me) its got an 80mm then i added a 70mm reducer onto my maf, i plan and making a custom heat shield, then adding my cold air feed and ensuring its all nicely blocked up, when its all finished i will post up pictures but i still got my anni rear, silicone pipes and lights to fit just can't find the time :( but for now here is a poc my my folter as she is atm.
Current - MK6 GTi Edition 35
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #38 on: 30 December 2012, 10:06 »
Anyone got a link to the eBay shield?
Offline davemk4
« Reply #39 on: 30 December 2012, 12:19 »
