Author Topic: what's your airbox mod?  (Read 7380 times)
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: what's your airbox mod?
« Reply #20 on: 26 December 2012, 14:57 »
In the rr air box thread the open filter has a massive fan blowing on it and with a open bonnet so no hot air is around the filter.
It then gives better torque than a standard box, but the torque is matched by a modified top half air box. I can't see the cone filter getting any more gains than that on the road.
Why even waste money on a cone filter? When you get same results as a modified top half air box.
I'm then adding two 100mm cold feeds to that box. You telling me I won't see any gains?
I think someone has had a heavy Xmas and is not thinking things through.
i would bet you that u see no gians nor feel any gains
id agree i wouldnt spend money on a cone if i dint have to, but somethimes its the only route to take
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline tweed
« Reply #21 on: 26 December 2012, 15:15 »
I doubt ill do it in all honestly as I'm still gonna vr it, but if the Hellas come up cheap ill give it a go.
And yeah that grill  :sick: what a joker  :grin: only opened the box two weeks ago.
When I vr mine I want it loud and already got a simota carbon loud box on it only like vr6's for the noise so its got to be loud. :grin:
But I do stand by what I say! I do think it will give more than 1bhp and that's slower than 100mph.
If I had a turbo yes I would go out and buy a cone filter because that is the only way to go. But certainly isn't on a N/A
Offline tweed
« Reply #22 on: 26 December 2012, 15:23 »
I've done 10,000 in 2 years and 3 months  :grin:
And I think that's to much.
VW BUSH
« Reply #23 on: 26 December 2012, 18:19 »
Reckon a 16v needs about .92 Cubic m/s at full chat, VW must have made it at least 90% efficient in the factory.
To increase intake pressure (without going on about bernoulli) a turbo needs to pump more than this figure.
What hope does an 80mm bit of pipe have?
To put it into perspective .92 CmP/S is about 5500 lts per min, the engine is drawing this in on its own.....
My maffs is a bit out granted as im suffering a port headache but you get the picture
I think the OP would be happiest with a cone filter or a giant hole, just for the sound and the backfire on engine breaking, did me for years :grin:
Offline tweed
« Reply #24 on: 26 December 2012, 18:43 »
Have you read this thread?
I'm on about two 100mm feeds.
And why work cubic m/s at fall chat?
Why not work it out in litres at 4000rpm?
To get boost you need to go from 1 atmospheric pressure to 1.01
1 atmosphere is 14.6 psi
Most standard turbos are 7psi. I'm sure most people are running 12psi.
So you only need 1 psi to get air inlet pressure.
What bhp gains do you recon you would get from say 0.5psi to 1psi
Offline tweed
« Reply #25 on: 26 December 2012, 18:51 »
To make it easy for you a 4 cylinder 2.0 engine will use 1 litre of air every 1rpm.
VW BUSH
« Reply #26 on: 26 December 2012, 19:58 »
3373 lpm at 4000 rpm with an efficiency of .85........
Why not try four 20 cm pipes, you may need a dump valve with all that boost your building
Offline tweed
« Reply #27 on: 26 December 2012, 20:20 »
N/A engine at 4000rpm will have minus - pressure, a vacuum because its sucking air.
Lets just say it -7psi at 4000rpm. Now I ain't believing that I will get boost, that's just plain stupid.
Why you are thinking that is beyond me?
I do think that I can lower the vacuum inside the air box with a big cold air feed. So the engine doesn't have to suck in as much air.
And at 4000rpm the engine will be sucking 4000 litres of air. That's 66.6 litres a second.
How are you working your math out?
VW BUSH
« Reply #28 on: 26 December 2012, 21:21 »
Volumetric efficiency of 85%, just one of many variables when calculating air flow and fluid dynamics.
The one of the variables you are playing around with by flowing an air box or intake manifold.
