Author Topic: Rallye headlights Adjustment guide on page 3  (Read 73954 times)
Offline car_maniac
Re: Rallye headlights, Adjustment guide on page 3
« Reply #20 on: 20 December 2012, 20:16 »
ive had the lights on and played about with the bulb position and the only way to get the beam in the right sort of direction is when its out of its seating but then the holding clip cant be put over the bulb.
This is why im willing to pay for someone to sort this for me who might have a better idea
« Last Edit: 27 December 2012, 22:34 by Thom89 »
Offline rallye_golf
« Reply #21 on: 27 December 2012, 21:41 »
I have done a little 'how to' on adjusting rallye headlights..
Firstly check that you have them set either to RHD or LHD.
This can be changed by slackening the three screws marked here in Yellow, and rotating the projector housing.
This is marked L/S and R/S, this is referring to what side of the road the car is being driven on, not what hand drive it is!
It will probably be easier to remove the headlight to do this, they are only held in with four screws.
Then the actual beam adjustment.
This is done by turning the adjusters marked here in this pic, the red arrows are dipped beam adjustment, one up and down, one left and right (not sure which is which, have to turn one and see which way the beam moves!)
The green arrows are for main beam adjustment.
Dippeds beam are easy, just turn the thumbwheels by hand. Main beam can be adjusted through the slam panel with a suitably sized phillips screwdriver.
pics explain all..
Dipped beam adjusters from another view.
Hope this is of help!! :grin:
Offline Thom89
  • Looking for an "Icebreaker"
Re: Rallye headlights Adjustment guide on page 3
« Reply #22 on: 27 December 2012, 22:41 »
Hello, and welcome to the forum, great input! thank you :cool: :cool:
Thom
