Author Topic: relaying headlights  (Read 2620 times)
Offline vwwvgolf
Re: relaying headlights
« Reply #10 on: 20 December 2012, 12:33 »
i know the bulbs will have bit of tolorance but wont running them above 12 shorten their life and such?
also if the battery is 12 volt how would you increase it to 14??
and would taking the earth from the headlights and run it striaght to the battery negative work for making new earth?
Offline javalin
« Reply #11 on: 20 December 2012, 12:59 »
car off = ~12v, car on (alternator running) = ~14v
it would.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline vwwvgolf
« Reply #12 on: 20 December 2012, 13:15 »
nice one.  been looking into it some more and a 1 volt drops appers to make huge diiferance. will be doing this when i get the bits!
Offline ttelracs
  • The Fettler
« Reply #13 on: 21 December 2012, 13:16 »
I did the 'matey-matey' co0nversion myself and yes it made a difference.
I then bought some Halfords +90% brilliance bulbs and lo and behold I could see in the dark sooo much better.
I will be cleaning up the earthing mounts, but getting to the one underneath the battery is a pain in the arse.  May simply make another !
Offline vwwvgolf
« Reply #14 on: 27 December 2012, 12:40 »
was just about to go out and get the bits i need to make up the relay but thought i would check the voltages again. i properly disconnected them at the block connector this time just behind the lamps and got reading of 13 to 14 volts on dipped and main beam.
 i duno if my battery was a bit down last time i checked or what but was looking forward to improving my lights.  :sad:
passengers side had intermittent voltage and the connector is pretty soaked in oil so will clean the connections up with some electrical connection cleaner to see if that helps.
is it possible that my alternator is not as efficient as it needs to be when the heaters are on with the wipers, stereo and headlights? (if stereo is on 2 amps will also be running)
if my bulbs are getting the voltage is there anything else i can try or look into?
Offline javalin
« Reply #15 on: 29 December 2012, 21:42 »
I've not checked this, but as I said I don't think the mk3 suffers from the same voltage drop issue as the mk2.
worth checking that that the headlight levels are adjusted correctly, if they are pointing down then no amount of voltage or better bulbs will help.
Start the car, turn everything on, headlights, stereo, heated windscreen's etc, and measure the battery voltage.  Should still be ~14v.  Also worth checking voltage between the battery neg terminal and the engine block - should be < 0.5v.
James
Offline vwwvgolf
« Reply #16 on: 31 December 2012, 12:24 »
mine had a mot not too long ago so they should have been checked then and adjusted if needed then.
thanks for the info javalin. i will check the voltage with all on later on
