Author Topic: Hello! MK3 GTI ABS issue-could do with a bit of advice please....  (Read 5479 times)
Offline Jasikasisback
Re: Hello! MK3 GTI ABS issue-could do with a bit of advice please....
« Reply #10 on: 17 December 2012, 21:15 »
man is it just as good as vag?
Offline trog_nfs
« Reply #11 on: 17 December 2012, 21:20 »
Man; is it just as good as vag?
Is it just me or with some extra punctuation can the meaning of this be completely changed?
« Reply #12 on: 17 December 2012, 21:33 »
what about the cheapy stuff from hong kong for a quid on ebay and a laptop? anyone ever used that?
Offline javalin
« Reply #13 on: 18 December 2012, 10:18 »
does that read the ABS controller?  I thought the cheap ones only did the ECU?
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
VW BUSH
« Reply #14 on: 18 December 2012, 21:16 »
Does the lot and resets/clears, I have only needed vagcom once for calibration of the throttle body :smiley:
These guys aint the cheapest but sell all readers and will give you advice, I have a super duper one which does all cars from 96 to present day. I bought it for my dad but he only understands steam and coal :grin:
http://www.talktomycar.co.uk/products/codereaders/codereaders.htm
Offline John W
« Reply #15 on: 21 December 2012, 18:52 »
Thanks guys. Turns out it's definitely water-related. The light went out soon afterwards and only came back on when I went through yet another lake with the nearside wheel this time! This too went out after a day. I think I need to get the vaseline out and insulate those sensor connectors!  :grin:
Kind regards
John
1997 VW Golf GTI 8V 5 door
1979 Porsche 924 Lux
1982 Porsche 924 Lux Auto
1986 Porsche 944 Lux
1996 BMW 525iX SE Touring (4x4)
Offline Screech16v
  • MK3 20vt AGU
« Reply #17 on: 26 December 2012, 19:02 »
Ive got the bottom one ,used it lots and lots ,great little scanner,think the cheap leads are dodgy  :wink:
« Reply #18 on: 27 December 2012, 10:37 »
Thanks for the advice..will order this scanner and use the money santa claus brought to enjoy it!
Offline geeksteve
« Reply #19 on: 27 December 2012, 10:46 »
The mk3 has a design flaw that means the ABS loom and the crank sensor and coil share a bundle of cables. In damp weather this produces interference. I've been looking for the notice online that detailed it - if i find it i'll post it here. In a nutshell - let it dry out and clear the code. You can separate the looms and tie one to the side (against strut housing) but it's a lot of effort - I never bothered.
