Author Topic: the 3" system  (Read 17065 times)
Offline dom
  • Back in a Mk4
Re: the 3" system
« Reply #130 on: 29 December 2012, 20:09 »
Just for reference really, but I measured the volume of mine before....84db at idle about 3ft from the tail pipe. I'll get a reading from inside the car later.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: the 3" system
« Reply #131 on: 29 December 2012, 20:20 »
Same as me then Dom. Will get onto the exhaust place in the new year and get it sorted.
BTW add me on Instagram lol
Offline dom
  • Back in a Mk4
Re: the 3" system
« Reply #132 on: 29 December 2012, 22:06 »
Have you done any research into silencers that could be added in? There's a couple of Jetex ones I was looking at but not sure what size will fit and where?
What's your instagram name?
Offline dom
  • Back in a Mk4
Re: the 3" system
« Reply #133 on: 30 December 2012, 00:02 »
And some more readings, all taken inside the car....
On idle - 65dB
70mph/3000rpm - 75dB
'Booting it' - peak of 85dB
I was keeping an eye on it as safely as I could and normal driving saw 70-80dB
Offline davemk4
Re: the 3" system
« Reply #134 on: 30 December 2012, 08:12 »
That great news on the db readings! Not too bad at all
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: the 3" system
« Reply #135 on: 30 December 2012, 09:42 »
Dom - wazzzer79. Not sure on the measurements but I'm putting my silencer where the cat should be
Offline davemk4
Re: the 3" system
« Reply #136 on: 30 December 2012, 12:14 »
just curiously what DB is a jetex/milltek etc? roughly?
Offline dom
  • Back in a Mk4
Re: the 3" system
« Reply #137 on: 30 December 2012, 14:10 »
Yeah that's what I was thinking of doing. What kind of silencer you going for?
I'll add you on instagram in a sec :wink:
