Author Topic: Heater control bulb  (Read 851 times)
Offline mk2man1
Heater control bulb
« on: 16 December 2012, 19:26 »
Hi all just changed the bulb and the centre dial is bright green a normal but two outer ones are hardly lighting up.
The bulb was 2.3 watts is that bright enough or did i get the wrong bulb.
The cost of living is going up and the chance of living is going down
Offline itavaltalainen
Re: Heater control bulb
« Reply #1 on: 16 December 2012, 19:43 »
Hi mate, yes you got the wrong bulb.... standard is 12V 1.2W not 2.3/2.4. So could we be the reason for the middle lighting up like a christmas tree and comparatively little on the outer ones.
The only other reason would be that you haven't replaced the "spider" properly....
« Last Edit: 16 December 2012, 19:45 by itavaltalainen »
