Author Topic: Agu remap and immobiliser remove  (Read 8920 times)
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: Agu remap and immobiliser remove
« Reply #10 on: 27 December 2012, 21:06 »
Lol
Just confused myself........
Immo off is £100 inc P&P.   I would not take the risk of loading a map in there without seeing the car.
 01455 617233
Offline Dave-iow
« Reply #11 on: 27 December 2012, 21:58 »
Shame as ive not got the spare time at the mo to get the car to a tuner just want a base map to get it on the road.
Have you not done a postal map for wes in the past??
Dave
Offline 0138hutchy
« Reply #12 on: 31 January 2013, 21:07 »
new to the forum i have an agu mk4 and ive bought a ko4 tt injectors etc and a mapped ecu to suit but trouble is i have no key can still get hold of the clocks for the car but if i just get immobaliser removed as above^^^ will it just plug in and work? any advice etc would be much appreciated.
thanks
hutchy
Offline topher
  • Administrator
  • fully functioning
« Reply #13 on: 31 January 2013, 21:18 »
if the mapped ecu is from another AGU then you can just adapt it to your immobiliser with vcds. If its not an AGU/m3.8 ecu then its not going to work on your car at all. Whats the part number on it?
Offline 0138hutchy
« Reply #14 on: 31 January 2013, 21:33 »
thanks for the reply it says made in germany 11.06.99 so im assuming it from the agu one?
also whats vcds? lol
« Last Edit: 31 January 2013, 21:56 by 0138hutchy »
Offline Wazzzer
  • Golf GTI 1.8T AGU
« Reply #15 on: 31 January 2013, 21:42 »
Has it got a VW part number on it starting with 06A?
Offline 0138hutchy
« Reply #16 on: 31 January 2013, 21:46 »
yeah mate its 06A 906 018 CG
cheers
Offline topher
  • Administrator
  • fully functioning
« Reply #17 on: 01 February 2013, 10:08 »
thats AGU alright that should code in fine. I'm sure there's a couple of members up your way with vcds (vagcom) that could help you adapt it to the car. Pop a request in the mk4 section
Offline 0138hutchy
« Reply #18 on: 01 February 2013, 21:35 »
ok thanks for the info so it will just code onto my clocks and key with vagcom? Sounds easy enough... :huh:
Offline Wazzzer
  • Golf GTI 1.8T AGU
« Reply #19 on: 10 February 2013, 12:21 »
All I did with mine was to clear out the ECU coding, recode the keys to the ECU (I think I only had to do this as I have immo3 clocks) fire up the car and job done
    Install the new ECU in the car
    [Select]
    [17 - Instruments]
    [Adaptation - 10]
    Leave channel at "00"
    [Read]
    [Save]
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    [Exit]
    Turn ignition OFF for 15 seconds. Start vehicle.
Or in my case, have the clocks beeping at you saying the immobiliser is active...
