Author Topic: what the hell is this???  (Read 2291 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: what the hell is this???
« Reply #10 on: 13 December 2012, 18:10 »
Air con compressor bearings? Is your AC turned on?
Offline cooki
  • 1.8T AUM
« Reply #11 on: 13 December 2012, 19:24 »
It may not be the pump, but does sound like it. Something is definately not right. It could also be alternator bearings though i doubt it. I would take off the aux belt and start the engine and see if noise goes away, if it does you will know its one of the parts run by said belt causing the issue. ( if you see what i mean)
Understood mate yes thanks. Prety hard to do tho because it only does it on cold start
1.8T AUM,18"s,full koni suspension kit,forge split r on fully recirc,k&n induction with cold air feed,FMIC,r32 front,colour coded rear valance,black front and rear VW badges,5 door wind deflectors,boost gauge an volt metre in A pilla pod,full brushed alluminum net optic interior,full creame heated interior,
PLANS: catback exhaust&remapp her  :) :) :)
Offline cooki
  • 1.8T AUM
« Reply #12 on: 13 December 2012, 19:25 »
Havnt got aircon at all mate.
Offline Nino
« Reply #13 on: 14 December 2012, 00:27 »
Does it only do it for about 90 sec then stop?
Current - MK6 GTi Edition 35
Offline cooki
  • 1.8T AUM
« Reply #14 on: 14 December 2012, 01:03 »
I dont no about the 90 seconds mate but it defo only does it for a short time period. Poss till var is warmer.
What u thinking????
Offline Nino
« Reply #15 on: 14 December 2012, 07:34 »
I was thinking could it be the secondary air pump?
Offline GTi_James
« Reply #16 on: 14 December 2012, 08:57 »
mine makes a whirring clicking noise and gets louder depending on time used with higher setting and mode  :undecided:
Offline GOLF-MK3-GTI
« Reply #17 on: 14 December 2012, 10:03 »
Take the cambelt cover off and check if one of the bolt of the pulley has beocme loose, This happend to a figaro turbo engine, i gave in for recon and when i got it back, i fired it up and it was maing a similar noise to this, and upon inspection, one of the bolt was loose from the pulley.
I was lucky it didnt get in the way of the cambelt and wrecking a newly recond engine  :lipsrsealed:
« Last Edit: 14 December 2012, 10:05 by GOLF-MK3-GTI »
