Author Topic: ClimaTronic  (Read 2190 times)
Offline PaulMK4GTI
ClimaTronic
« on: 19 July 2005, 18:50 »
Quick question. I have a Mk4 GTI (Non-Turbo) with ClimaTronic. Is this unit supposed to be air con? Because if it is i think it's broke! In the past week's heat wave i've noticed even on the 'lo' setting it's not that cold, nowhere near as cold as air con.
TIA
Offline topher
  • Administrator
  • fully functioning
Re: ClimaTronic
« Reply #1 on: 19 July 2005, 18:58 »
there's a "lo" setting ? .. try turning the fan speed up and setting the target temp (blue button) to something stupidly low like 15 degrees, if it still isnt blowing cold you probably need it recharged.. or worst case scenario its broken :undecided:
Offline GazB
  • Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
Re: ClimaTronic
« Reply #2 on: 19 July 2005, 19:10 »
my climatroniconly goes to 18 degrees, then it says "lo" :undecided:, but when it is on lo, its feckin freezeing
Offline R32_T
Re: ClimaTronic
« Reply #3 on: 19 July 2005, 20:35 »
That is correct, same as mine
2001 20V Turbo        1997 VR6 Highline
"Granny shifting not double clutching like you should"
Offline GazB
Re: ClimaTronic
« Reply #4 on: 19 July 2005, 21:01 »
still not sold the beast then?
Offline topher
  • Administrator
  • fully functioning
Re: ClimaTronic
« Reply #5 on: 19 July 2005, 21:05 »
why do you ever have it set that low... bloody eskimos ! :grin:
Offline charri42
Re: ClimaTronic
« Reply #6 on: 19 July 2005, 23:29 »
make sure its on 'AUTO' mode, then if its still not ice cold you have a problem
Offline PaulMK4GTI
Re: ClimaTronic
« Reply #7 on: 21 July 2005, 09:39 »
Cheers everyone, mine also only goes as low as 18 degrees and then to 'LO'. It does blow out cold air but just not as cold as other air con units i've experienced, maybe it does just need recharging, i'm due for a service next month anyway so i'll get it looked at.
Cheers again.
