Author Topic: Crankshaft pulley bolt snapped.....help!! mk3 gti 8v  (Read 6189 times)
Offline tweed
Re: Crankshaft pulley bolt snapped.....help!! mk3 gti 8v
« Reply #10 on: 11 December 2012, 22:10 »
Why were you taking that bolt out?
Does it matter why? It's snapped and needs a answer.
I use bolt extractors. You need to drill a hole the the bolt. Then then turn the extractor in the hole you drilled. The thread is opposite, so as you turn and tighten the extractor anticlockwise the bolt should undo.
They look like this
Photo0374 by tweedub, on Flickr
Would like to see you drill through high tensile steel on a crank tbh... Especially when you think thats a pritty f**king tight and large bolt too. And obvioulsy snapped with a socket on it and probably a huge bar. So an easy out and vice grips wouldnt cut in my opinion....
And reason i asked was because i had a feeling he was maybe thinking that crank bolt was for taking the bottom aux belt pulley off to get the bottom timing cover off. Iv seen people think that when they take out the allen key bolts but the aux pulley still wont come off because its seized to the crank pulley. So thats why Tweed i asked my question... So i grand sceme of things... Could actually matter.
He's drilling a bolt not a high tensile steel crank numb nuts!
The head of bolt would have snapped off, so it won't be tight any more. It's just a thread in a hole.
What do you think drills are made of, chewing gum?
Use metal drills with cutting fluid to keep it cool.
Your question still means nothing! Even if he didn't need to undo it, he still has snapped it and needs it removed.
So if my way is wrong and you doubt it will solve it, maybe in your next post tell us how to get it out!
Offline CJA321
« Reply #11 on: 11 December 2012, 22:17 »
They look like this
You actually speak utter pish.... Classic case of a keyboard warrior who seems to think he knows all and everything but has obviously put very little into practice....
I merely gave my input to your solution.
Its gonna be a total ball ache no matter what you do. Worst case scenario iv seen cranks removed and have to be machined out.
« Last Edit: 11 December 2012, 22:20 by CJA321 »
Offline tweed
« Reply #12 on: 11 December 2012, 22:24 »
I never comment on a thread when I have no experience on the matter.
So what is your solution to removing the bolt?
Try helping the lad
Offline Bellend
« Reply #13 on: 11 December 2012, 22:26 »
Hopefully you can remove the pulley now it's snapped? Is the thread itself free?
Where all my moneys went.
Offline CJA321
« Reply #14 on: 11 December 2012, 22:34 »
Try helping the lad
Tbh re-reading the thread it depends on which bolt. Because im assume hes on about the actually multi spline bolt the goes into the crank itself. If so, you could try driling it with some high quality drill bits but this is high tensile and re tap it. But that has risks itself. Or as you said, try and easy out. But as iv said, if its tight enough to snap in first place good luck...But as iv also said, thats even harder in my opinion. Worst case, get it machined out. But then you have to ask if thats even worth the hastle.
If its an aux allen bolt, bit easier. But you will need to take it off the the toothed pulley and put it in the vice. As allready said  :rolleyes:
« Last Edit: 11 December 2012, 23:09 by CJA321 »
Offline Bellend
« Reply #15 on: 11 December 2012, 22:50 »
Got any pics mate? If literally the head has snapped I'd remove the pully put a grinder line down the middle of the bolt sticking out and turn with a thin flat bar.
All depends really. Thing is, it's not something you want coming loose so you don't want to wreck the thread.
Just thought actually if it has snapped it must be tight in the thread unless you were doing it up as apposed to loosening it in which case I'd probably not use extractors as I'd hazard a guess that that would snap just as easy. I would drill bigger and put a thicker bolt in personally.
Saaaying that my dad has some pretty damned decent extractors. I'll try find out the make Screech. Far better than snap on. They're a fair few years old though.
VW BUSH
« Reply #16 on: 11 December 2012, 23:03 »
The spline bolt is 14 x1 iirc which if seized could make it mega stuck.
Drilling down the centre will help but you have to be super straight and close to the edge to release it.
Fine threads have a bigger core diameter so you can trash the female thread proper easy if you go off centre.
Utter ball ache to do and best off in a vice as no room underneath, you can get the crank out in car but is tricky and best off with a mate and a few bits of wood and ties to wedge the pistons.
Chance it if you feel lucky, if your not you know how to do it properly :grin:
Offline Rossco250
« Reply #17 on: 13 December 2012, 21:19 »
I wasnt taking the bolt out mate. it snapped while i was driving :cry: Not sure if its done any internal damage... so i need to get the other half of the bolt out so i can get the new one in and connect my belts up again to see if it has done any real damage.. Are these bolts reverse thread?
Offline Rossco250
« Reply #18 on: 13 December 2012, 21:26 »
Thanks for all the responses lads. Will try getting a pic up in the morning..
Offline Rossco250
« Reply #19 on: 13 December 2012, 21:34 »
And yes i'm talking about the big mutha in the middle that goes into the crank  :cry:
