Author Topic: stuttery agu (fixed)  (Read 3477 times)
Offline Screech16v
  • MK3 20vt AGU
Re: stuttery agu (fixed)
« Reply #30 on: 18 December 2012, 19:08 »
If that's the case,would it have been runnin a bit lean then? i guess the cheap maf  may have been over reading.
Offline Chris.
« Reply #31 on: 18 December 2012, 22:36 »
no idea.  as long as new maf rads fine then its oke.... whats boost psi like?
Click For Build Thread
Offline Screech16v
  • MK3 20vt AGU
« Reply #32 on: 18 December 2012, 23:37 »
Well it was boosting to 15psi but now only 11 max and drops off in higher revs is this normal
Edti.. also when engine is not up to temp it seems to have restricted boost not that I cane it when cold but I know a guy whos agu doesn't seem to do this
« Last Edit: 18 December 2012, 23:41 by Screech16v »
Offline Chris.
« Reply #33 on: 18 December 2012, 23:56 »
Guess your mapped?
Any logs you can do with vagcom?  Could be 'new' maf is under-reading loads giving less boost?
Offline Screech16v
  • MK3 20vt AGU
« Reply #34 on: 19 December 2012, 19:51 »
Under reading over reading I just want one in the middle   :cry: :grin:
It will have to do for now,get crimbo out the way first .
