Author Topic: Rockmonkey's little rabbit  (Read 129185 times)
Offline rockmonkey69
Re: Rockmonkey's little rabbit
« Reply #10 on: 06 November 2014, 23:59 »
I've ordered some bits for the golf:
« Reply #11 on: 09 November 2014, 22:15 »
Polished the turbo compressor housing
Got a few more integrated engineering parts
Set of integrated engineering camshafts
Start of mock up
Ran out of time so just bought the manifold and bought another wastegate to accommodate
Polished my oil filler cap a little
Heatshielding added for coilpack loom
Changed the oil return line - previous one was a bit bodged and I didn't like the way it looked
Added some heatwrap and heat shielding:
« Last Edit: 08 February 2015, 16:37 by rockmonkey69 »
« Reply #12 on: 11 February 2015, 22:45 »
Car went in for mapping today with Bill at Badger5
Still a few things to sort out on the car, need a second uprated fuel pump and relocate the lambda sensor further upstream closer to the turbo. But the results speak for themselves, 491bhp with only 24 psi boost, the turbo is still half asleep, after several dyno runs nothing is glowing.
« Reply #13 on: 17 February 2015, 22:34 »
Started to tidy up my next brake upgrade, I plan to keep my 13" two piece rotors
And of course some nice fittings and adapters to go with my inline da31 pump (sytec intank feeding)
« Last Edit: 19 February 2015, 23:57 by rockmonkey69 »
Offline xtetx
« Reply #14 on: 26 February 2015, 08:47 »
I've not been on the forum in a while, but i used to regularly read this build!
Epic work! Its come such a long way, and everything is OCD under the bay.
Top work!
« Reply #15 on: 26 February 2015, 19:48 »
Top work!
Thanks bud! It's always nice when people appreciate the work that's gone into the golf, especially so when it's a fellow enthusiast - someone like yourself would better appreciate the work done than someone passing by at the petrol forecourt and with what you said I know I'm on the right track.
I'm possibly looking at a 4motion shell I can drop everything into, I missed out on one this morning, was in a meeting when the auction ended at £340, absolutely gutted at that price. I'm going to keep looking for a bargain like that one, with 4motion I should be able to turn up the boost a bit.
« Reply #16 on: 08 March 2015, 09:10 »
Fuel pump installed:
Fuel filter in oem location:
More positioned lambda sensor:
And bought a 4motion golf:
Offline xtetx
« Reply #17 on: 09 March 2015, 13:24 »
Top work!
WELL! THIS JUST GOT INTERESTING :D 4MO!
« Reply #18 on: 09 March 2015, 13:31 »
I intend to keep it locked in 50:50 permanently, it will drive less like a haldex and more like a torsen 4wd, it should hold down the power pretty well and be quite good in snow/ice too.
« Reply #19 on: 20 April 2015, 00:33 »
So I recently got back from holiday and got stuck in - and I'm happy to report there's progress
Vr6 removed
« Last Edit: 21 April 2015, 02:00 by rockmonkey69 »
