Author Topic: turbo seal replacement £120  (Read 1925 times)
Offline Jack111
Re: turbo seal replacement £120
« Reply #10 on: 05 December 2012, 17:43 »
in a way if it needs a rebuild its already [ballsed up] we take full responsibility for our work and am myself running a k03s rebuilt about 30,000 ago still going strong
Golf Agu,K03s,Front mount,Tip,Decat pipe turbo back,BBS chs,Cupra r splitter,Boost guage,On its ass low,Hid's,Smoked lights,Full respray jet black
Offline Prawny
  • R-tech power!!!
« Reply #11 on: 05 December 2012, 18:00 »
yes all seals and bearings replaced and the units are balanced when new parts are introduced thanks
That's cool man, wasn't trying to put you down at all, just wanting to make sure it's clear that you're offering a complete service, not just a 'throw in some seals and send it out' affair
Offline Jack111
« Reply #12 on: 05 December 2012, 18:18 »
no probs thanks for your comments mate i would do the same  :smiley:
Offline Luke1981
« Reply #13 on: 05 December 2012, 18:20 »
How quickly can you get the turbo returned?
and
what are the symptons of a failed turbo seal?
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline Jack111
« Reply #14 on: 05 December 2012, 18:51 »
the process takes 3 days 1 to pick up 1 to repair and post back, you will receive back on the third day
symptoms of a blown turbo seal =heavy blue smoke from exhaust.  where the oil is passing the seal into the exhaust chamber and being burnt causing blue smoke
reduced performance is also another symptom
loud whirling noises at low revs usually means bearing damage or compressor /turbine wheel
thanks
