Author Topic: brake pedal going hard  (Read 3634 times)
VW BUSH
Re: brake pedal going hard
« Reply #10 on: 03 December 2012, 22:59 »
is the abs light on
Offline sharki786
  • GOT BOOST??
« Reply #11 on: 04 December 2012, 18:20 »
no it only comes on when the ignition is turned on then back off
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline JamesS
« Reply #12 on: 05 December 2012, 13:12 »
This may be something to check. When I did a vr6 conversion on my mk2 I initially used the 280mm setup with a second hand corrado brake master cylinder. When I drove the car for the 1st time the n/s/f wheel was locking up and the pedal feel stiffened. I ended up removing the brake hoses going to that wheel, checking them and ended up replacing the Rado brake master with a new G60 brake master which completely solved the problem. The Rado master had some form of blockage, due from rubber breaking down/being old so maybe you have a similar problem. Also brake hoses can collapse/deteriorate internally and a small flap of rubber inside can prevent fluid travelling one way or another causing a stiffer pedal or uneaven braking after you have presuurised the system from braking a few times.
Either trial and error fitting new parts or you could take it to a garage to see if the wheels are braking evenly, if not then it could be a hose/hoses, if they all brake evenly then it could be the brake master. Sounds like you have checked the servo for vacuum leaks as this has been mentioned previously.
Hope you get it fixed   :tongue:
AEROSPACE GRADE CNC MACHINED VR6 KEYRINGS. ONLY £16.50 INC P&P.
http://www.mk2vr6.com/board/viewtopic.php?f=28&t=13053
Offline sharki786
  • GOT BOOST??
« Reply #13 on: 05 December 2012, 21:45 »
see thats the fuuny thing. it dont happen all the time. it only happens hen i brake hard a few ties then th pedal will be solid & if i drove a mile or so the brake pedal goes back to normal (a nice push)
*****MK4 GTI T*****
Offline Len
« Reply #14 on: 06 December 2012, 13:02 »
Brake fade = the surfaces (disc/pad) get hot and then do not work as efficiently.
simples!
www.sas.org.uk
www.the-ace.org.uk
Offline sharki786
  • GOT BOOST??
« Reply #15 on: 08 December 2012, 14:08 »
simples!
cheerio len :wink:
*****MK4 GTI T*****
