Author Topic: Biasi Boilers....  (Read 3926 times)
Offline The rock
Re: Biasi Boilers....
« Reply #10 on: 25 November 2012, 21:06 »
i work for warrington and wigan councils as a spark . im in need of a new boiler so have been doing lots of homework as to which boiler to get . luckily i have about 20 plumbers nd heating engineers to pick the brains of . we fit bosch and vaillant which are big money ( to much for my budgt to be honest) i seen the biasi riva 24k on screw fix and in b and q . i asked several of our engineers and they said exactly what has happened to you . they said by all means they d fit one , but they d be back in 18 months 2 years to put a proper one in . you ve confirmed for me what they said . hope it gets sorted for you mate and you dont get any more problems .
VW BUSH
« Reply #11 on: 25 November 2012, 21:18 »
Meh, this seems to be the going interweb diagnosis.
Looks like I have to get it fixed and save up, keeping the Mk3 for another year then :cry:
Offline justalex81
« Reply #12 on: 25 November 2012, 21:38 »
biasi and ferroli are the devil. fit one at your peril. worcester bosch are mid range and vaillant ecotec plus are top end.
Loads of engineers fit the rubbish ones so they get the breakdown work once it's out of warranty.
Offline chrisowen85
« Reply #13 on: 26 November 2012, 19:40 »
we only fit worcester bosch boilers on the basis we get a 7 year guarantee on them so it pays to spend a little bit more on the boiler. £120 + vat for a pump is a bit of a joke, we buy grundfoss pumps for £55 + vat!
Offline raferackstraw
« Reply #14 on: 26 November 2012, 20:21 »
get britishgas boiler cover mate about 11quid a month and all parts and labour included as well as yearly service. also you could have tried british gas one off repair, before i got cover they quoted me £114 to repair over the phone, it turned out to be a waterlogged pump, boiler was a worcester greenstar, so with callout, labour and part they had to stick to quoted price  :cool:
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Offline Ant1981
  • Feed me, prod me
« Reply #15 on: 27 November 2012, 07:16 »
Waterlogged pump?  :huh:
'09 Kawasaki Ninja ZX-6R
Offline justalex81
« Reply #16 on: 27 November 2012, 18:33 »
must be one of those new waterless pumps  :grin:
« Reply #17 on: 27 November 2012, 20:18 »
yep what had happened was we had very heavy rain lashing against the back wall off the house where the flue terminal was, now as the terminal is low down the water had run back down the flue and saturated the pump electrics and apparently burnt it out, hence waterlogged. it happened on a second occasion but this time had left a puddle underneath the gas valve and the wire to the valve was lying in the water causing a short. the problem of water has been solved by drilling some holes in the outer case of the flue where it meets the wall so allowing rain water to drain rather than run down flue.
does that explain waterlogged pump well enough for you guys now?
Offline Ant1981
  • Feed me, prod me
« Reply #18 on: 27 November 2012, 21:57 »
Right, so basically, there were an ingress of water onto the electrics causing a short, rather than this bullsh!t term of waterlogged pump.
Offline justalex81
« Reply #19 on: 27 November 2012, 22:48 »
Who drilled the holes in the flue?
