Author Topic: What the hell  (Read 2708 times)
Offline GTi_James
Re: What the hell
« Reply #10 on: 21 November 2012, 11:09 »
the lights didnt flash when i locked the car, so took to my mates at VW and ran a cheeky diagnositics when he was on lunch, found a few engine splutter codes and old codes that the previous money wrenching garage i took it to on my first service did not remove, funnily enough after removing these codes all my interior lights started working properly and both puddle lights worked, he then reset the alarm with the above process and hey presto its worked...has had its odd moment when i have had to reset it but it all works and also that annoying passenger side module that cause the lock to pop open when using the convienience controls has stopped happening for the last month as well  :huh:
Offline Ant1981
  • Feed me, prod me
Re: What the hell
« Reply #11 on: 21 November 2012, 18:46 »
Just tried it, not a sausage from the indicators.
'09 Kawasaki Ninja ZX-6R
Offline GTi_James
Re: What the hell
« Reply #12 on: 21 November 2012, 20:31 »
and all your doors are fully closed etc? i noticed mine wouldnt flash even if the windows were a little open  :undecided:
Offline Ant1981
  • Feed me, prod me
Re: What the hell
« Reply #13 on: 21 November 2012, 22:53 »
Yea, all closed and everything.
Just to be sure, where's the bonnet switch? I looked, couldn't see one. It's not in the mechanism is it like the how doors are done?
Offline GTi_James
Re: What the hell
« Reply #14 on: 22 November 2012, 08:23 »
its normaly a handle operated cable for bonnet, i think you may have to take all the doors off and either re-solder your modules or replace them as it sounds like theres a loose/broke connection somewhere  :undecided: and you've checked for codes?
Offline Ant1981
  • Feed me, prod me
Re: What the hell
« Reply #15 on: 22 November 2012, 09:04 »
I wondered though if there were a switch to sense if the bonnet were left open.
As for the left hand door, it's a faulty micro switch, usually is, there's rarely anything to solder.
I replaced the right hand switch and sorted that one out. The door switches wear as they're plastic and they operate from a metal cam in the door mechanism.
Offline GTi_James
Re: What the hell
« Reply #16 on: 22 November 2012, 09:18 »
i only know of the boot sensor  :undecided: it could be a case of opening up your doors then unless theres a bright spark out there who knows something we dont. i would personally take the doors apart, check everything and disconnect and then reconnect the battery, atleast you know you've done all the basics and reset everything
Offline rio_gti
Re: What the hell
« Reply #17 on: 22 November 2012, 10:03 »
Yes there is a bonet sensor dunno where thou but I have been leavin my bonet open and it doesn't beep when lock is pressed
Offline GTi_James
Re: What the hell
« Reply #18 on: 22 November 2012, 13:15 »
well there we go lol  :grin:
