Author Topic: ko3s  (Read 2025 times)
Offline cooki
  • 1.8T AUM
Re: ko3s
« Reply #10 on: 19 November 2012, 21:59 »
Silenced and unsilenced have different pipes too due to them being slightly different OD too
That was going to be my next question.
So silenced and unsilenced are diff sizes also.
In theory would be better to try order a straight 51mm as my pipe work is 51 mm,then also order a smaller 46mm-51mm reducer so I've covered both angles.
Does anybody no the inlet/throttle body size??
1.8T AUM,18"s,full koni suspension kit,forge split r on fully recirc,k&n induction with cold air feed,FMIC,r32 front,colour coded rear valance,black front and rear VW badges,5 door wind deflectors,boost gauge an volt metre in A pilla pod,full brushed alluminum net optic interior,full creame heated interior,
PLANS: catback exhaust&remapp her  :) :) :)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: ko3s
« Reply #11 on: 19 November 2012, 22:34 »
Chris the 90 degree pipe is the same part number but the suffix letter is different. Silenced version comes forward slightly to meet the metal boost pipe. AGU/ARZ/AUM are all the same, AUQ has the different pipe
Offline Reesy23
Re: ko3s
« Reply #12 on: 20 November 2012, 09:18 »
Throttle body pipe needs to have an Internal diameter of 63mm
