Author Topic: Misfire on acceleration but fine on motorway :-/  (Read 7345 times)
Offline tshirt2k
  • Been there...Done that...
Re: Misfire on acceleration but fine on motorway :-/
« Reply #20 on: 19 November 2012, 15:59 »
have you changed vacuum lines as i mentioned earlier? old original rubber can collapse under vacuum
Mk3 ABF 16VT Megasquirt V3
Offline car_maniac
« Reply #21 on: 19 November 2012, 16:57 »
No not yet.
Is it a diy job with a few spanners 'cos i have no idea about that?
An online guide somewhere maybe?
If they do colapse is the engine still able to run smoothly at times and/or go from that to misfiring like turning a lightswitch because that what its like driving it.
Offline tshirt2k
« Reply #22 on: 19 November 2012, 17:12 »
Yes DIY. Very easy, Buy it from ebay 3m should do it.
Offline car_maniac
« Reply #23 on: 19 November 2012, 17:27 »
4mm or 5mm
is there any guide on where they are supposed to go to and from because i dont have a clue on this?
Offline tshirt2k
« Reply #24 on: 19 November 2012, 20:26 »
3mm id.
Offline Len
« Reply #25 on: 20 November 2012, 13:07 »
The long hose up to the ECU is a favourite as it has to pass through the skuttle and can get compressed there.
www.sas.org.uk
www.the-ace.org.uk
Offline car_maniac
« Reply #26 on: 20 November 2012, 15:28 »
is the ecu below the windscreen infront if the passenger?
Offline Jasikasisback
« Reply #27 on: 20 November 2012, 22:01 »
just wondering what relay is equivalent to no 30 on the 1.8 AAM automatic engine?
Offline tshirt2k
« Reply #28 on: 20 November 2012, 22:18 »
Should be
Offline car_maniac
« Reply #29 on: 23 November 2012, 12:34 »
just swapped the vacuum pipe...no difference
So far vacuum pipie, spark plugs,coil pack, ecu relay (doubt it will be the fuel pump relay or ignition leads) have been swapped.
Any other ideas?
I think I said before, it misfires accelerating (even less than 1/4 throttle when properly warm sometimes) from low revs but if i lift off then put my foot down again it goes fine
it will do it pretty much any time i floor it though, goin from low or high revs, hot or cold
