Author Topic: Polybush top mounts  (Read 10217 times)
Offline PolRay
Re: Polybush top mounts
« Reply #20 on: 19 December 2012, 12:04 »
Si there's a way round the top plate problem
Polybush manufactured the uprated polyurethane strut top mounts merging the existing MK4 Strunt Top Mount with the shorter Polo MK3 Strut Top mount thus gaining the 10mm additional suspension drop. This means that when fitting the Polybush Strut Top Mounts that Polo MK3 Top Cap (OEM Number 6N0 412 319) has to be used to ensure correct location and fitment,
I have fitted a number of the Polybush mounts myself with Polo Top Caps and have no issues with fitment or Knocking.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #21 on: 19 December 2012, 12:48 »
Tried them, the rubber surround was destroyed within a day and they fall through the strut top as they are too small. Pics to follow of my hybrid versions I finished today
Offline SI74
« Reply #22 on: 19 December 2012, 15:48 »
PolRay did you read the link posted? We all know about the Polo cap but like Wazzzer says its not the fix.
Offline wotavudunn
« Reply #23 on: 19 December 2012, 17:08 »
just use a big washer job done.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #24 on: 20 December 2012, 13:45 »
Here you go.
Standard Golf cap with the cup part cut off leaving a big washer
Then the remaining lip ground flat and centre hole enlarged slightly
Polo and modified Golf cap mated together
Comparison of difference in diameter between the two caps
Rubber buffer added to both caps
Will be fitting them after work this evening, can't see any reason why they won't do the job
Offline SI74
« Reply #25 on: 20 December 2012, 15:56 »
Job done!
Offline PolRay
« Reply #26 on: 21 December 2012, 08:59 »
It worked for me and many other so confused, has anyone spoken to Polybush with regards to this I know they would be interested in speaking to people who have had first hand experience.
Offline PolRay
« Reply #27 on: 21 December 2012, 09:08 »
Wazzzer have you spoken to Polybush on your findings I know they would be interested to speak to you, as far as I am aware they have not been made aware of any issues with fitment
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #28 on: 21 December 2012, 10:47 »
No I haven't mate, might well drop them am email and see what they say. Not interested in trying to get anything free etc bit would be nice to get it sorted for others
Offline rio_gti
« Reply #29 on: 21 December 2012, 11:39 »
are the 2 parts welded together??  :undecided:
