Author Topic: Storm Developments Stainless Exhaust  (Read 6650 times)
Offline DaveHDi
Re: Storm Developments Stainless Exhaust
« Reply #10 on: 14 November 2012, 20:33 »
Ok that's brilliant. Thanks buddy.
Offline Ess_Three
« Reply #11 on: 14 November 2012, 22:23 »
According to the late Bill Byldenstein, there is nothing wrong with the standard downpipes and cast manifolds on the VR6...so I wouldn't go expecting any gains on a standard engine.
Certainly the 225+ BHP 2.9 VR6 I built was managing just fine at 7300 RPM (with a big valve head and Schrick 268 cams) on standard manifolds and downpipes.
Personally, on a standard engine I'd spend the £300+ elsewhere...unless you absolutely NEED the bling.
..but gaining motorcycles.
Offline tweed
« Reply #12 on: 14 November 2012, 22:34 »
To be honest I would fit itb's just for the noise, as they ain't much use on a vr6 that doesn't like to rev.
Offline popleyruss
« Reply #13 on: 14 November 2012, 22:55 »
Being from basingstoke so have autobahn the phirm united Motorsport and unfortunately storm on my door step I've heard some shockers about them as for the manifold even the cheap ones from hot tuning are supposed to be ok
Most people I no run dub power or united Motorsport ones
Just plain dubbin
Offline Ess_Three
« Reply #14 on: 14 November 2012, 23:00 »
Doesn't like to rev, eh?
Lose some weight off the crankline and swap the cams and it revs...like you wouldn't believe!
That's still on plenum injection, and saddled with the standard VR6 'box.
Offline tweed
« Reply #15 on: 14 November 2012, 23:06 »
What was the rev limit and power?
I can't help but think I could spend loads on a 12v but still only get 225 max. Where as a can get the 2.8 24v and remap it to that for little money.
In a mk3 obviously
Offline Ess_Three
« Reply #16 on: 14 November 2012, 23:13 »
In a mk3 obviously
It was unmapped there...so probably 7000RPM.
Well built 2.9 on a 2.9 TB, when mapped was making 225+ BHP and 200+ lb-ft, revving to 7300 RPM IIRC, and pulling to the fuel cut.
It's true though...big money 2.8/2.9 = mapped 2.8 24v...or standard 3.2 24v power wise.
Offline robo22sri
« Reply #17 on: 15 November 2012, 12:01 »
That sounds the nuts!!!!!
Offline Rob Zombie
« Reply #18 on: 15 November 2012, 16:48 »
I cant comment on the manifold itself howveer i can say that Storms work is hit and miss.
MY rotrex c30 s/c was fitted to my mk2 by those guys and they did a real good job...  :cool:
Performance mods: Revo stage 2 map, 5 Peice Hose Kit & TIP, Evoloution Motorsport Air Filter, N249 by-pass, Forge spliter valve, ECS N75 Valve, KW 50mm springs &shocks, Front & Rear Eiabach ARB, Full Milltek Turbo back exhaust.
BHP: 231
TRQ: 251.7 lb-ft
Offline topher
  • Administrator
  • fully functioning
« Reply #19 on: 15 November 2012, 16:52 »
had a dubpower manifold on my jetta, no flexi.. it didn't crack, even when the exhaust hanger failed at 90mph and dragged the exhaust half a mile up the A5 :grin: . Can't really comment on the gains it was already fitted when i bought the car.
