Author Topic: Rear Lights Not working..fuses OK what to look for now?MK3 1.4CL  (Read 2719 times)
Offline adyspriggs
Hi Guys,
you  have helped out in the past and info recieved really helped me out
new problem
i don't have any working rear lights, the fuses are ok there is one blown bulb, took that out yet still no lights from the others...
recently the dash has been playing up with intermittent display...temp/fuel/speedo/rev counter
i've noticed that the windscreen wipers are faster that previously when everything was working fine
any ideas apart from giving up on this OAP that has grown on me over the past couple of yrs
cheers for any info
Ady
Just found the indicators work ok :smiley:
« Last Edit: 13 November 2012, 08:53 by adyspriggs »
Have you checked for power at the lights, could be a switch problem
Offline Len
Also check the earth wire above drivers side cluster.
www.sas.org.uk
www.the-ace.org.uk
Offline sharki786
  • GOT BOOST??
brake light switch? i think what normaly happens is that the lights stay on when the switch goes faulty
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline adyspriggs
great thanks guys all sorted
Offline Screech16v
  • MK3 20vt AGU
Well what was it then ?  :grin:
Offline vw_tees
?  :nerd:
Offline adyspriggs
sorry for the delay......it was a loose wire in the cluster plus a blown bulb..
