Author Topic: gearbox help  (Read 1553 times)
Offline hobbiniho
gearbox help
« on: 11 November 2012, 14:04 »
right my friend has a mk3 gti with a 20v turbo fitted and his gearbox has decided to spit out the diff rivets resulting in a nice big hole ad it pissing all the oil out.
the box is an o2j with the code ewp and it has 108mm drive flanges now from what i have managed to find out not all o2j's have the 108mm drive flanges but i was wondering if they are a straight swap for the 100mm ones?
am i right in thinking that any o2j will bolt in?? i will just be the ratios inside that will be different??
cheers michael
Offline Screech16v
  • MK3 20vt AGU
Re: gearbox help
« Reply #1 on: 11 November 2012, 14:06 »
100 mm should bolt straight in  :wink: i did some not long ago although i put 100mm cups from an o2a into an 02j
« Last Edit: 11 November 2012, 14:08 by Screech16v »
Offline hobbiniho
Re: gearbox help
« Reply #2 on: 13 November 2012, 17:37 »
ok cool anybody got any recommendations on where to get a refurbed box from??
Offline Ess_Three
Re: gearbox help
« Reply #3 on: 13 November 2012, 20:05 »
Re-furbished, or uprated?
Surely there is a lesson to be learned here, regarding the standard diff rivets?
..but gaining motorcycles.
Re: gearbox help
« Reply #4 on: 14 November 2012, 11:03 »
As Glen said get the rivets replaced with bolts, much stronger.
