Author Topic: Relay  (Read 1618 times)
Offline Mark b
Relay
« on: 06 November 2012, 13:37 »
Hi could someone here let me know where and how I get to the relay pref with pictures as need to check one for my rear wiper
Standard gti 2.0 115bhp 2000 w reg
Offline Dalo Harkin
Re: Relay
« Reply #1 on: 06 November 2012, 19:08 »
do you mean relay or fuses?
fuses are on the side panel of the drivers side (access gained with the door open)
only relays I have ever seen are in the engine bay (passenger side) to the left of the suspension strut in the black box
Offline Mark b
Re: Relay
« Reply #2 on: 07 November 2012, 01:20 »
Sorry didn't phrase it properly basically my rear wiper don't work but the jet was does so before I start to think its a broken wire thought I'd check the relay to see if that's a possible reason it stopped working wasn't until yesterday I even knew what a relay was as u can guess I have 0% knowledge about cars lol
Offline Chris.
Re: Relay
« Reply #3 on: 07 November 2012, 02:14 »
Rear wipers dont have a relay.
Sure its not a fuse or wiper mechanism seized?
Click For Build Thread
Offline Mark b
Re: Relay
« Reply #4 on: 07 November 2012, 09:03 »
A bloke at work use a tool he had in his car couldn't tell u what it was but he connected it up to the wiper and it was moving so I know it does work so would it most prob be a broken wired ?
Offline Mark b
Re: Relay
« Reply #5 on: 20 November 2012, 10:59 »
Can't see a break in the rubber gromit would it have broken further up If so how do I get to it would i need to take off the electrical clip from the motor and pull it through the boot to examin all the wiring ?
Offline EsSeX dAn
Re: Relay
« Reply #6 on: 20 November 2012, 11:47 »
check your fuses first before you start taking things apart
i think i love you.....
Offline Mark b
Re: Relay
« Reply #7 on: 20 November 2012, 12:01 »
Will do what fuse it for the rear wiper ? if the fuse is good what else should I check
Offline Mark b
Re: Relay
« Reply #8 on: 20 November 2012, 22:20 »
Offline beppe2672
Re: Relay
« Reply #9 on: 01 December 2012, 19:21 »
The fuse for the rear wiper is located on the top of the relay panel, which is behind the trim above your pedals. It's 15 amp I believe!
1999 1.8t AGU, KNN Panel filter, Smoothed air box, Custom CAI, Forge 007 dv, REVO stage 1, 3" eBay TBE. Audi TT quickrack.
To come - A DIY hybrid K03 and a whole lot of supporting mods!
