Author Topic: 3 Grand to spend, what would you do?  (Read 4483 times)
Offline the_hamster
Re: 3 Grand to spend, what would you do?
« Reply #10 on: 05 November 2012, 17:59 »
Both petrol and dev Anni golfs on eBay for £3000
I had a look, and I cant find one for 3k or less, unless its a shed.
Offline dom
  • Back in a Mk4
« Reply #11 on: 05 November 2012, 18:01 »
If you're after a derv then it should be either a PD130 or PD150. From what I've read the PD150 is the better of the two...has different turbo, injectors, inlet & FMIC. With a good remap you'll see 190bhp & 300+lb/ft.
The PD150 is known to have cams made of chocolate so I'd be looking for one that has already had them replaced.
Offline dom
  • Back in a Mk4
« Reply #12 on: 05 November 2012, 18:07 »
Thanks chap but i'd be interested to see what the petrol guys have to say on this and what realistic performance I can get for my budget.
As for a petrol, £3k would see you with a pretty well sorted 1.8T. You'll be able to pick up a decent one for around £2000, leaving you with another £1k to spend straight away. I'd be looking for an earlier AUM engine, and look at upgrading the turbo at a later date.
With your £1k I'd be looking at sorting handling first...decent coilovers (KW or similar), polybushes, arb's, brakes, then a good service and remap (with an upgraded recirc valve).
Further down the line....FMIC, exhaust, KO4, injectors, 3" MAF, S3 fuel pump, TIP, silicone hoses etc.
Offline SI74
« Reply #13 on: 05 November 2012, 18:15 »
£3250 57'000miles, full history, 3 owners. 15 hours left. Not far off £3000
Offline asboGTI
« Reply #14 on: 05 November 2012, 18:18 »
No change for modding
vw golf mk4 ARZ 1.8T pipercross panel filter, xenon headlights, JOMS coilovers, forge 007p with green spring, audi tt anti roll bar, 3inch ebay trubo back exhaust, COOKIES MONSTER STICKER(adds bhp I swear)
Offline the_hamster
« Reply #15 on: 05 November 2012, 19:07 »
As said, that would be the very top end of my budget and can anyone please tell me what makes an Anni worth nearly double (in some cases) what a stocker is. How much would it cost to buy a stock gti and get it to Anni spec?
Offline Chris#101
« Reply #16 on: 05 November 2012, 19:11 »
Buy a late model golf sort of '52 plate + with an AUQ lump and youve pretty much got an anni spec with out the looks. 180bhp K03s 6speed box, 312mm vented front brakes 256mm? rears etc etc
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline dom
  • Back in a Mk4
« Reply #17 on: 05 November 2012, 19:15 »
Then the lights, valances, side skirts, seats, clocks, alu trim etc.
If your fitting genuine parts then you'll be looking at about a grand for that lot.
Offline Nino
« Reply #18 on: 05 November 2012, 21:43 »
My antie is currently selling her MK4 Black GT TDI 130. on 92k, on a 52 plate.
Pm me for details if your interested.  :cool:
Current - MK6 GTi Edition 35
Offline bobbieboy69er
  • MK4 1.8T AUM
« Reply #19 on: 05 November 2012, 21:59 »
buy mine!  as in my sig, very well looked after, 86k...... you dont want a derv :cool:!!
MK4 1.8T AUM|30mm Eibach Springs|Milltek cat back|4mo rear valance|pipercross filter|R-tech Stage 1 Remap|Baileys DV|Powerflex Front and Rear Bushes|312mm Front Brakes|Creation Motorsport TIP and hoses|17" TT Ronals|  220BHP
