Author Topic: Mk4 2.08v BAD Misfire - Advice Needed  (Read 1356 times)
Benjo
« on: 15 July 2005, 13:09 »
I have a terrible misfire on my mk4.
Doesn't matter what speed you're doing, whether the engine is hot or cold etc.
You put your foot down and nothing happens, then after quite a while it catches up with itself, gradually gaining speed but still extremely lumpy (like it's going between 2 and 3 cylinders on and off). I was drivin to work this morning with my foot to the floor in 2nd and maxed out at 12mph!!!!!!!!
Already replaced the front lamba sensor and plugs.
Help!!
Any advice appreciated!
Offline CHR15
Re: Mk4 2.08v BAD Misfire - Advice Needed
« Reply #1 on: 15 July 2005, 13:55 »
faulty coolant temp sender would be my guess and i work at a vag dealer so hopefully i know what im talking about!!
Offline topher
  • Administrator
  • fully functioning
« Reply #2 on: 15 July 2005, 13:58 »
dont think temp sender would affect it that badly, although it is a common failure. i wouldn't buy any more parts for it until it's been on a diagnostics machine though.. could be a lot of things. injectors, throttle body and MAF all spring to mind.
Offline CHR15
« Reply #3 on: 15 July 2005, 14:06 »
MAF sounds like a fairly good suggestion also
