Author Topic: clutch mod  (Read 2498 times)
Offline mkviken
clutch mod
« on: 04 November 2012, 09:44 »
the reason the gTI clutch is so poor is down to the dual mass flywheel and this bleed block which is also a fluid restrictor to dampen down the pedal feel
http://www.ecstuning.com/Volkswagen-Golf_VI--2.0T/Drivetrain/View_All/ES251250/
there is an after market one for the mk5 but not the mk6.
the OEM one linked above can be modified by simply removing the clip and the bleed nipple part then the restrictor just falls out.
as far as i can find this has the same affect as the aftermarket part and gives the clutch pedal more feel/modulation
anyone tried this on here?
this is the aftermarket one
http://www.ecstuning.com/ES2215340/
Golf GTI 7.5 230 white silver
Offline MS1COYS
  • Alfie 'H' 10-09-11
Re: clutch mod
« Reply #1 on: 04 November 2012, 12:31 »
I'd be interested to see how this works on the standard clutch. I've toyed with the idea of an uprated clutch since I modified the car, but maybe there's no need  :smiley:
292bhp / 287lbft
Offline mkviken
Re: clutch mod
« Reply #2 on: 04 November 2012, 16:13 »
i think i might give it a go next week.
Offline MS1COYS
Re: clutch mod
« Reply #3 on: 04 November 2012, 16:15 »
Let us know how it goes fella and what the 'labor' time involved is. Cheers  :smiley:
292bhp / 287lbft
Offline mkviken
Re: clutch mod
« Reply #4 on: 04 November 2012, 17:26 »
i will order a new one from vw and modify that one so if it goes wrong i can revert back to the old one
