Author Topic: clutch mod  (Read 1163 times)
Offline mkviken
clutch mod
« on: 04 November 2012, 09:43 »
the reason the gTI clutch is so poor is down to the dual mass flywheel and this bleed block which is also a fluid restrictor to dampen down the pedal feel
http://www.ecstuning.com/Volkswagen-Golf_VI--2.0T/Drivetrain/View_All/ES251250/
there is an after market one for the mk5 but not the mk6.
the OEM one linked above can be modified by simply removing the clip and the bleed nipple part then the restrictor just falls out.
as far as i can find this has the same affect as the aftermarket part and gives the clutch pedal more feel/modulation
anyone tried this on here?
Golf GTI 7.5 230 white silver
