Author Topic: Fogged up windscreen  (Read 6017 times)
Offline Snooze
Re: Fogged up windscreen
« Reply #10 on: 03 November 2012, 08:08 »
Hi guys thanks for your responses. Gonna give my screen a gd clean first see if that helps. I thought having the aircon on helped? I'll try turning it off!
2015 Mk7 Golf Gti 3dr Manual, Carbon Steel Grey, Michelin PS4's
Offline JonnyG
« Reply #11 on: 04 November 2012, 16:55 »
I've had this a few times in the past when the cold damp weather starts  :sad:
I've found the following the best way to keep it at bay :-
1.  I never turn the AC off in wet weather (the next time you start the car it will dump damp moist air into your cabin).  I either keep AC on all the time or keep it off all the time.
2.  I give the internal windscreen a good clean to clear the "film" that develops.
3.  When convenient I turn up the heater and fan up to max, and get the cabin really hot, to dry out any damp.  Open the windows a little by a cm to let the damp escape.
4.  Repeat the above at first sign of condensation or after having wet clothing / jackets/ umbrellas in the car.
Current : Seat Cupra Lux, DSG, Magnetic Grey, Sept 2019
Gone :    Golf Mk 7 R, 5dr DSG, Pure White, March 2017
Gone :    Golf Mk 7 R, 5dr DSG, Tornado Red, March 2015
Gone :    Audi RS3, Daytona Grey, 7sp S-Tronic, Sept 2012
Gone :    Golf R, Rising Blue, 5dr DSG Mar 2010
Gone :    Golf R32, DBP, 5dr, DSG, Nov 2008
Gone :    Golf GTi ED30, Mar 2007
Offline Booth11
« Reply #12 on: 06 November 2012, 21:20 »
Sorry you misunderstood me, the a/c will clear it but its the fundamental cause when you then leave the car in winter as it leaves the ambient air in the car slightly moist, hence the steaming up when left.
Took me about 3 months into winter last year to find this out and once I stopped using the a/c and just the heaters it cured the problem.
I've had problems with fogging taking ages to clear with all my golfs, but Raffe's advice to turn air con off and just use heaters has done the trick.  Last few days windows have cleared in seconds!  Thanks  :smiley:
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Snooze
« Reply #13 on: 06 November 2012, 21:27 »
I also tried turning the a/c off and it did the trick! Cheers guys
Offline Raffe
« Reply #14 on: 07 November 2012, 07:31 »
Picked tip up off Seat Cupra forum as car was driving me mad last winter, glad it's helped :cool:
