Author Topic: can i do this?  (Read 1430 times)
Offline rfn_hodgson
can i do this?
« on: 02 November 2012, 16:41 »
my friend and i was wondering if you can put a mk5 or mk6 r32/ r engine block into a mk4 r32??
as a straight ish conversion??
VW Golf MK4 1.8 Turbo AUQ 203 BHP-more now :) , ultimate vacuum delete, Forgre 007p-new piston, Oil catch can, s3 boost set up, FMIC, silicone TIP, full turbo back exhaust, stage 1 map, lowered on V-maxx coilovers  audi tt Quattro alloys
Offline dan2252
Re: can i do this?
« Reply #1 on: 02 November 2012, 16:54 »
Why do you want to mate? Doubt it because I'm sure the mk5 r32 is a fsi engine which means your gonna have to change wiring and alsorts of stuff  I don't see why you would want to though? And they didn't so a mk6 with a vr6 engine mate
MK4 golf 1.8 turbo agu :)
Offline dom
  • Back in a Mk4
Re: can i do this?
« Reply #2 on: 02 November 2012, 18:10 »
The MK4 & Mk5 R32's have the same blocks/head/cams, the difference is in the ECU, wiring loom, plugs, injectors, fuel rail etc.
I believe it is possible to use MK4 ecu/loom etc with a Mk5 block, but I'm not 100% about that.
Although it's possible I don't there is much point in it....power is pretty much the same for both engines, a lot of work for little gain.
The Mk6 R engine will be harder to fit and a damn sight more expensive, not got a clue what's involved in that tbh.
Offline barrym381
Re: can i do this?
« Reply #3 on: 02 November 2012, 18:38 »
best stickin a bam engine in and a bigger turbo prob cost you the same an will see good power from that  :smiley: but anthing can be done if you have the cash,saw a mk2 golf with a passat r36 in it last week
Offline cullygti
Re: can i do this?
« Reply #4 on: 02 November 2012, 20:13 »
as barry says anything is possible if you have money and time  :wink:
but my first option would be a bam lump with a hybrid turbo then theres plenty of power with a few other supporting mods  :cool:
Re: can i do this?
« Reply #5 on: 02 November 2012, 22:09 »
Why not keep your engine and fit a k04 etc.
Offline madmanmart
Re: can i do this?
« Reply #6 on: 02 November 2012, 23:12 »
Just take you engine out and fit in a mk2/mk3
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: can i do this?
« Reply #7 on: 02 November 2012, 23:14 »
You're kidding right?!
Offline Rhyso
Re: can i do this?
« Reply #8 on: 03 November 2012, 08:27 »
Most things are possible. Its mainly a question of time and money. Also helps if you got some skills as that will help keep the cost down!
Bloke on ukmkivs has fitted the 2.0 GTI ED30 engine to his MK4 but its a very awkward conversion as all the electrics etc are different
Every man and his dog has done that  :whistle:
« Last Edit: 03 November 2012, 08:36 by Rhyso »
Offline dom
  • Back in a Mk4
Re: can i do this?
« Reply #9 on: 03 November 2012, 10:10 »
They're swapping it into a MK4 R32 so fitting a KO4 wouldn't be easy :wink:
