Author Topic: I got Horn problem  (Read 1133 times)
Offline Tezmax
I got Horn problem
« on: 02 November 2012, 02:34 »
Ok my horns stopped working after a few weeks of playing up.
I've found two horn sirens under the front near side bumper.
Which one needs changing or is it both?
Thanks  :smiley:
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
Offline rio_gti
Re: I got Horn problem
« Reply #1 on: 02 November 2012, 10:40 »
check weith a multimeter that you are getting power there first  :wink:
Offline Ant1981
  • Feed me, prod me
« Reply #2 on: 02 November 2012, 10:46 »
Check the fuse first.
If that's ok, connect a meter across the terminals of the horn and press the button and see if you get voltage. If you don't get the voltage and the fuse is ok, check the relay, if that's fine then check the switch.
It's less likely to be the horn itself, but it could be.
'09 Kawasaki Ninja ZX-6R
Offline Tezmax
« Reply #3 on: 02 November 2012, 14:16 »
Thanks for the feed back guy's :smiley:
Fuse was ok so had a closer look and found one 13m nut was all what held them on!
So took em both off, flashed them on the battery and neither worked :shocked:
Got two more, flashed them before fitting and sweet as :wink:
Now got a proper mans horn, think ive only been running on one since i bought it :laugh:
Thanks again.
Offline Ant1981
  • Feed me, prod me
« Reply #4 on: 02 November 2012, 19:32 »
I've got a set of air horns knocking about somewhere, I might fit them to my roof bars  :grin:
Offline tokemk4gti.t
  • 2001 gti turbo :-)
« Reply #5 on: 03 November 2012, 10:21 »
ive got a horn problem to i just wana hang out the back of women all the time i might have a faulty sensor :-S
