Author Topic: PD130 box of tricks on fuel sensor  (Read 2268 times)
Offline Dolly
« on: 30 October 2012, 17:06 »
just sorted my 130PD i brought from a mate for £500.  (mk4 ibiza ASZ)
running VAGCOM 11.11.4 to check injector quantities as its not very smooth i now think its DMF..
But i noticed the fuel temperature to be 137 Degrees!  :laugh: so i looked into it and theres a little box plugged into the sensor and then the proper plug connected to this.
its looks like some kind of ebay special, i have removed it and now it reads 30 degrees which is better.
Any come across this before and what would of been the benefits?
Offline Agreeable Slick
  • Unit
Re: PD130 box of tricks on fuel sensor
« Reply #1 on: 30 October 2012, 17:19 »
Sounds like a dirty way of tricking the engine to overfuel, as diesel can be used to cool down the chamber, so if it is reading that the temperature is high it might dump a bit more in to try and cool it down.
Only problem then is that over time the injectors will lacquer up and will need replacing... along with other items being affected long term. :Sad:
Offline Dolly
« Reply #2 on: 30 October 2012, 17:52 »
sounds like cheap ebay wank now in the bin  :laugh:
Offline Dolly
« Reply #3 on: 31 October 2012, 11:30 »
as i suspected... £4.99
http://www.ebay.co.uk/itm/TDI-Diesel-Tuning-Chip-PD-VW-Jetta-Golf-MK4-Golf-MK5-Lupo-Multivan-Passat-38BHP-/190746454208?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2c695fe8c0
Do not buy this sh!t and fit it to your car, it seems to be running better without it and it should increase mpg  :rolleyes:
Offline topher
  • Administrator
  • fully functioning
« Reply #4 on: 01 November 2012, 18:39 »
I pulled one of these off a customer's car recently because it was causing problems, then remapped it properly. I'm fortunate enough to have a dyno to play with so i'll let the pictures do the talking. The car was a 110 tdi
Offline Dolly
« Reply #5 on: 02 November 2012, 08:08 »
 :grin:
Im only down the road at Four Ashes ( BMW specialists ) Maybe i should drop my 130pd round, get it mapped  :evil:
