Author Topic: Hockey puck engine mount ?  (Read 3498 times)
Offline Khare
  • The bear that khares
Re: Hockey puck engine mount ?
« Reply #10 on: 22 October 2012, 09:35 »
3.5 it is then :grin:
And ebay, 5 for 10.75 I think.
Offline spudboy6
  • Just like a golf ......
« Reply #11 on: 15 November 2012, 00:04 »
Fitted today took no more than 15mins to do
Used 2 pucks then the rubber support then half a puck on the bottom with the washer as I thought any more pucks would be to stiff so used some of the old mount
Works a treat no excessive engine movement anymore
I have got a spare puck and a spare half if anyone needs them (pre drilled ) means you only need one from eBay to make a mount up that's not going to rattle your dash to death .
Offline tshirt2k
  • Been there...Done that...
« Reply #12 on: 15 November 2012, 11:04 »
Tshirt knows :afro:  :grin:
Mk3 ABF 16VT Megasquirt V3
Offline spudboy6
« Reply #13 on: 06 December 2012, 21:43 »
Had the puck set up in not even a month and today going down the road the mount lower bolt vibrated lose and the puck on the bottom fell out !
After much searching in the dark and starting to snow .... I found the puck and washer but no bolt  :angry:
Anyone know the lower bolts dimensions?
Need one ASAP
cheers guys and girls
Offline tweed
« Reply #14 on: 07 December 2012, 05:09 »
Lock tight  :lipsrsealed:
Offline tshirt2k
« Reply #15 on: 07 December 2012, 11:34 »
Correct torque.
Offline spudboy6
« Reply #16 on: 07 December 2012, 22:12 »
Correct torque.
I lock tightened it today , what's the correct torque ?
