Author Topic: Planning the first detail for my 13 year old car!  (Read 5211 times)
Offline SI74
Re: Planning the first detail for my 13 year old car!
« Reply #10 on: 20 October 2012, 21:43 »
Thanks lads, Guts of 2 days.
to answer you question better you'll need a good range of pads and a few different grads of polish as I believe you'll not know whats going to work till you start.
Offline bobbarley
  • I'm kind of a big deal...
« Reply #11 on: 20 October 2012, 22:18 »
One of the reasons I like the kit I linked to before is it comes with 4 levels of polish, I start at 1 and work up to 4.  Each polish has an accompanying pad to go with it  :smiley:
Offline SI74
« Reply #12 on: 20 October 2012, 22:50 »
The Menzerna will work reall well on the hard VAG
I don't believe in the whole pads and accompanying polish.
Yea you start at one and work up but it's more like you start of with the lest CUT pad and polish if it don't work you then step it up a pad but stay with the same polish till you get a level of finish your after. So you could end up with a low cut polish and heavy cut pad working. Once you get on to it you'll start to know what pads/polish work well together.
Offline bobbarley
« Reply #13 on: 20 October 2012, 22:54 »
It's going to be interesting.  I've got to fill in and sand down 9 or 10 BIG stone chips, about 5mm wide in places, one has gone rusty.  Plus the mirrors and front valance I've got to re-spray first as well.
Offline SI74
« Reply #14 on: 20 October 2012, 22:58 »
Yea it's a real skill. Don't forget a wee dab of clear coat on top.
Offline Guy
« Reply #15 on: 21 October 2012, 23:11 »
would recommend the DAS6-pro... its the best DA i have ever tried, apart from the rupes bigfoot but even then i would probably plump for the DAS6-pro if i was to get one
