Author Topic: MK4 GTI 1.8T ARZ power issue  (Read 3975 times)
Offline james1981
Re: MK4 GTI 1.8T ARZ power issue
« Reply #10 on: 17 October 2012, 16:19 »
ill have a check now, do you know what clutch switch i need to buy, im assuming their are two next to pedal, just done know what to look for which one to buy.
Offline james1981
« Reply #11 on: 17 October 2012, 17:44 »
Right change of note lol, i deleted the DTC codes, took the car for a roughly 6 mile run and no codes have checked back in :smiley:, car seems to pick up a little better. Thought i might check if car is still picking up the fault codes because off something it said in the manual, so took the MAF sensor off and it picked up on that. so at the minute it seems all is mostly fine now. Just a quick question how major would a boost leak have to be for the computer to pick-up on it. I'm going to give it a fuel filter change as well because it looks like it's not been changed in forever and a day.
Offline james1981
« Reply #12 on: 21 October 2012, 12:46 »
I think i have found out that my car never had a GTI badge on it. apparently the 5 door just had the 1.8t arz engine put in it. Would it still have been mapped the same as the gti's on the line, if this is true. Also I'm looking to swap the turbo out anyone think this would be a good swap out.
http://www.ebay.co.uk/itm/K04-001-53049500001-Upgrade-Audi-A3-TT-VW-Bora-Golf-1-8-T-K03-Turbo-charger-/160797451449?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item25704664b9
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #13 on: 21 October 2012, 14:21 »
take some MAF readings through VAG COM on a 3rd gear full throttle run and see what you're getting
