Author Topic: Need some advice please  (Read 2204 times)
Offline Jimmyrallye
  • 20vt goodness
« on: 14 October 2012, 21:01 »
Righteo just currently done a mk2 conversion on my golf the guy who did it said he put a 16v box on but he has,nt and put my 8v gear box back on !!! Its holding out but i dont trust it all .. So question is what do i need to fit a 16v box as ive heard so many bits and bobs thought il ask the pro,s ... Thanks jimmy
Offline Gambit
Re: Need some advice please
« Reply #1 on: 14 October 2012, 21:09 »
To run 16v box you need 16v friction plate as input shaft is bigger
also, unless the 16v box has had the diff rivets replaced by the bolt upgrade then the 8v box will generally be stronger as its had an easier life. But diff is the weak spot in all mk2 boxes, they all let go eventually just 16v usually first
Offline Jimmyrallye
  • 20vt goodness
« Reply #2 on: 14 October 2012, 21:52 »
Cool thanks for the help again gambit so you would say im ok to run this gearbox on my car ? Also ive noticed theres a slight oil leak comeing out the green plastic circle thing on the gearbox
Offline Gambit
« Reply #3 on: 14 October 2012, 22:27 »
What is the conversion youve done?
Offline Jimmyrallye
  • 20vt goodness
« Reply #4 on: 14 October 2012, 22:34 »
Agu 1.8 20v turbo conversion early throttle cable engine
Offline Gambit
« Reply #5 on: 14 October 2012, 22:47 »
The diff will prob go at some point depending on how hard you drive it due to increased torque going through it. Slip diff is what you really want
The leak is probably coming from driveshaft flange seals if thats the green plastic circle you are talking about
Offline Jimmyrallye
  • 20vt goodness
« Reply #6 on: 14 October 2012, 22:55 »
Yep thats it buddy and yep its running a revo stage one remap so somethings going to give soon ... Thanks again gambit always to my rescue ;)
