Author Topic: Anyone know this mk1?  (Read 55328 times)
Offline higher1
Re: Anyone know this mk1?
« Reply #30 on: 30 December 2012, 21:20 »
built a wheel up to test fit i cant run a very wide wheel on the front as it has huge 4 pot calipers and need a spacer to clear them
new drivers door skin arrived so i ground the old one off
test fit of the new one
then spotted it in a couple of places before a trial fit on the car
popped it on with the wing for gapping etc and finished spot welding the door skin on
now the scuttle panel was for a LHD its all that was available so i welded the wiper holes up
also welded the aerial hole up on the wing
Offline higher1
« Reply #31 on: 30 December 2012, 21:22 »
the new wing needed the arch lip cutting down to help reduce any tyre rub
before standard large return edge
after edge cut back
the bonnet is a complete mess the previous paint prep was bad, the paint just flakes off with a chisel
as you can see the top was just a build up of paint and high build
a close up to show you how thick it was it totally ruined the defining lnes of the bonnet etc
out come the sander
im not running rear arch spats so i welded the holes up
still going on the bonnet lol
started to take the ns door back to
back to bare metal
the bonnet was a nightmare so out came the paint stripper
and it back to bare metal
Offline higher1
« Reply #32 on: 30 December 2012, 21:25 »
stripped the ns wing back to bare metal
and the same with the tailgate
that brings us upto date, so at last it was time to etch prime all the bare metal although theres a long way to go its a turning point for me as at last things arent being stripped or taken off
i would like to say im not a bodyshop guy or a sprayer im a mechanic and i work on motor caravans, this is the 1st time ive ever really done body work even though ive modified cars for many years.
panels ready for etch primer i borrowed some panel stands from a neighbour
[im]http://i50.tinypic.com/j79dnq.jpg[/img]
made good use of the 2 poster lift and hung the rest from it
and primed
Offline higher1
« Reply #33 on: 30 December 2012, 21:26 »
been working in the bay today tidying things up etc i needed a little more clearence between the turbo and chassis rail just behind the engine mount
so ive dressed the chassis leg in a little for some extra clearance
Offline higher1
« Reply #34 on: 30 December 2012, 21:27 »
so put some stone chip on the sills today the rest of the shell is almost ready for a coat of high build primer
Offline higher1
« Reply #35 on: 30 December 2012, 21:28 »
so today i painted the whole car in high build primer im soooooo happy with it all it really is a turning point and i now know it will be ready for painting in january
just a few spots need very fine attention
Offline higher1
« Reply #36 on: 30 December 2012, 21:30 »
Quick update i removed the chassis leg lip so i have more clearence with the drive shaft then welded it back up for strength
And found another gearbox with the code i wanted ENJ this has a higher ratio than the current gearbox and will allow a better cruising speed, i may even be able to put a little more power down in 1st,2nd and 3rd haha
gave it a quick clean i haven't decided on colour yet paint it silver or same colour as the body like the previous box?
Offline higher1
« Reply #37 on: 30 December 2012, 21:31 »
so ive removed the gearbox and checked the clutch it has hardly any wear but does have a little bit of movement in the centre drive so il replace it
carrying on with the colour coded parts theme the paint on the oil filter housing is looking shabby to so ive removed it ready to treat and paint
Offline SoundillusioN
« Reply #38 on: 06 January 2013, 03:00 »
Wow...... what a great rebuild this is... Lots of detail that's going to result in a very straight car!  Very jealous of your facilities too!  You might want to copy this thread into the dub rides section if you want more attention.  :afro:
Offline Wazzzer
  • Golf GTI 1.8T AGU
« Reply #39 on: 06 January 2013, 21:29 »
I'm looking forward to another passenger ride in it again :afro:
