Author Topic: Engine covers, do you use them?  (Read 2542 times)
Offline Nino
« on: 14 October 2012, 12:18 »
A few of you I have noticed you dont use engine covers is this because of a certain reason or have you lost yours of something?
Current - MK6 GTi Edition 35
Offline dan2252
Re: Engine covers, do you use them?
« Reply #1 on: 14 October 2012, 12:51 »
Mine won't fit due to boost pipes been in the way :)
MK4 golf 1.8 turbo agu :)
Offline AD1.8T
« Reply #2 on: 14 October 2012, 12:54 »
Strangely i have just put mine back on lol
If my recirc is fitted 'normally' ie nipple at the top i have it off as the vac line bends but ive just put it on backwards and refitted my cover
Offline rockmonkey69
« Reply #3 on: 14 October 2012, 13:22 »
I don't use them but that's because it serves no purpose in my situation and if it serves no purpose then it doesn't need to be there.
It's added weight so regardless of how little weight it is, if it serves no purpose then it is 'parasitic'
It hinders easy access when servicing or doing any work and obscures any leaks/defective parts, this is particularly important as I service and maintain every aspect of my car.
More things to keep clean, again I wan't to make my life as easy for myself as possible.
It is a potential thing to go wrong, loose or missing clips for the cover often means the cover vibrates and this can be misconstrued as a fault elsewhere
I also don't like seeing more plastic than engine in the engine bay, it's just personal preference. Although it can look good it does require the entire engine bay to be OEM and immaculate with no colourful pipes/hoses. Just depends what sort of look your going for and how tolerant you are of these covers.
They are certainly becoming increasingly popular with newer cars and you find you spend more time taking covers off than doing anything remotely mechanical.
Offline godsANGER
  • The black Money PIT - TDi ARG MONSTER! lol
« Reply #4 on: 14 October 2012, 13:25 »
i do as my engines tiny and makes it look a bit bigger lol, but running with out atm after a dissagrment with the cover i want to take it off it wanted to say on..... i won lol
Repairs Since 12/09 = £1860.00  *  Follow me on INSTAGRAM = w_all_ace
! thePOORmansBUILD !
Offline ReDBull
« Reply #5 on: 14 October 2012, 13:32 »
 :grin: that's the best thing to do with an engine cover rip it off!
03 210 Seat LCR. Badger5 V2.2TIP, Fordge 007p, Wellycooler, Quaife ATB LSD, Nuespeed ARB's, KW Clubsports, 330mm discs, 3" turbo back de cat and still on the standard map!
My project thread: http://www.golfgtiforum.co.uk/index.php?topic=241116.0
Offline Nino
« Reply #6 on: 14 October 2012, 13:42 »
Thats some good response's there guys, Thankyou, I was thinking people didnt use them because Of the heat it keeps under it etc
Offline godsANGER
« Reply #7 on: 14 October 2012, 13:47 »
but without it my engine looks sooooooooooooooooooooooooooooo small (because it is) lol
« Reply #8 on: 14 October 2012, 16:10 »
I will conceive that in some variants where the airbox is part of the engine cover itself then it's worth keeping, not least because it would be easier to keep everything oem and clean than rip everything off and make it look tidy underneath.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #9 on: 14 October 2012, 17:19 »
I like mine, keeps it nice and standard looking
