Author Topic: Radio Antenna Amp  (Read 1036 times)
Offline ss2115
Radio Antenna Amp
« on: 14 October 2012, 02:24 »
Just wondering if the Mk3 GL was fitted with an antenna amplifer for the radio?
Car had bog standard radio/cassette player and radio performance was pretty mediocre.
Changed in an Alpine unit with CD/MP3 etc, but radio performance is still pretty poor.
I've had the rear roof lining down and had a quick look to see that the antenna is connected and it appears okay. Tried a longer antenna temporarily but performance only improved marginally.
I don't have a proper wiring diagram for the car - only aftermarket which is pretty poor.
But many german cars with rear roof mounted antennas have inline antenna amps so I was wondering if the Golf did and where it might be located. Then I can start from there.
1997 Golf mkIII
1993 BMW 525i touring
1974 Citroen DS23 Safari BVH
Offline Screech16v
  • MK3 20vt AGU
Re: Radio Antenna Amp
« Reply #1 on: 14 October 2012, 13:53 »
Mine is poor also,and the polo 6n is poor and bosses 2k caddy is err... poor,its a vdub thing  :rolleyes:
Offline ss2115
« Reply #2 on: 14 October 2012, 22:13 »
Okay - thanks. That confirms then that its probably not a fault, but inherited in the car design.
So an inline booster will be the solution. Looking on eBay there are basically three types - the inline requiring the antenna cable to be cut and DIN plugs soldered in back close to the antenna, or the sharks fin with inbuilt booster, or there's a long antenna rod similar to the OEM antenna with inbuilt amp in the base.
Has anyone had experience with the the shark fin style or OEM style replacement?
1997 Golf mkIII
