Author Topic: handbreak light  (Read 3187 times)
Offline tweed
Re: handbreak light
« Reply #10 on: 13 October 2012, 20:02 »
You would think that.
But since your abs light is not coming on and the handbrake light is staying on. This points to rear abs sensor
Offline vwwvgolf
Re: handbreak light
« Reply #11 on: 13 October 2012, 20:11 »
Ah okay, me dad has a multi meter somewhere so investigate rear sensors when I have a chance
Thanks for the input guys
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: handbreak light
« Reply #12 on: 14 October 2012, 21:17 »
If you've had an ABS fault for some time the warning bulb may have burnt out.
Offline Screech16v
  • MK3 20vt AGU
Re: handbreak light
« Reply #13 on: 14 October 2012, 21:22 »
Yep i did three pods before my abs ecu was repaired  :grin:
Offline vwwvgolf
Re: handbreak light
« Reply #14 on: 15 October 2012, 16:58 »
just been out with the multi meter.
near side was showing reading of 1095
offside was showing reading of 1697
off side sensor needs doing then??
also had a look behind the abs light and gave it a poke and the abs light came straight back on.
still dont understand how it didnt come up in the fault scan tho??
Offline Screech16v
  • MK3 20vt AGU
Re: handbreak light
« Reply #15 on: 15 October 2012, 19:22 »
Looks like it mate i think they should be between 1000 to 1300 kohms
Offline tshirt2k
  • Been there...Done that...
Re: handbreak light
« Reply #16 on: 15 October 2012, 22:00 »
But even tho you may have a faulty sensor. Handbrake light points to a problem with the biasing which is dangerous. So don't go heavy braking.
Mk3 ABF 16VT Megasquirt V3
Offline vwwvgolf
Re: handbreak light
« Reply #17 on: 16 October 2012, 10:38 »
ah more possible issues lol. how would i go about checking if the bias system is working correctly?
is that somthing to do with the abs ecu??
Offline tshirt2k
Re: handbreak light
« Reply #18 on: 16 October 2012, 11:12 »
Scan controller. If you replace sensors and the faults still don't clear, then it's the ABS ECU.
Offline vwwvgolf
Re: handbreak light
« Reply #19 on: 16 October 2012, 13:31 »
okay.
thanks everyoone  :smiley:
